GT2 bucket in 991.2
#256
I'm planning on using the cantrell sport bucket sub belt mount (link). Would love to hear any other recommendations.
PCA requiers 6 point harnesses, and after looking into how harnesses work, I wouldn't use anything but that either. Looks like you'll need to rethink your seat occupancy sensor routing if you add the sub bar on the passenger seat.
And along similar lines, what is the appropriate attachment method for the lap belts on a six point harness? Adding a BK clip on adapter? I'd like to remove the belts easily when not in use.
#257
I can confirm the Cantrell sub belt mount fits on both the passenger and drivers side. Just make sure you install it on the passenger side before you start attaching all the new hardware under the seat so you will know where to attach it all under the seat.
#258
5-star shout-out to @marinb !
I completed the installation, and no airbag light. All airbags activated!
A few notes from my installation:
- My independent shop could not reset the airbag light. I took it to my Porsche dealer, explained in detail what I had done, and the technician was able to reset the light very quickly. He told me that he set the airbag section to think that it's a GT3 with new equipment. That reset everything. Quick and easy!
- There was a brown wire in the passenger seat wiring harness. I didn't know what to do with that. I first had it grounded, wasn't sure that was correct, then I just capped it off.
- I didn't bother connecting the seat heating for the passenger. This isn't a winter car, so I'm not concerned with that. Driver's heating works fine.
- I ended up going with the 4-point Schroth harnesses because I could not find an appropriate sub-bar. I know others have had success here, so I may revisit this.
- This must impact the memory module in some way. My mirror positions are memorized, but the AC is always "off" when the car is started. No big deal.
I got the Cantrell center belt mounts and the Driver's side is attached and in the car. I had to shift the angle of the airbag controller a slight bit but otherwise bolted right on and looks like a well made solution.
jimjoe997 (09-12-2022)
#259
I installed my seats this weekend in a 2018 CS. I used the approach where the new harness is a donor harness and added _just _ the wires needed to support the occupancy sensor on the passenger seat. It worked out just fine and no codes or airbag light. In the end you only need to add three pins/wires to the existing main plug for the occupancy sensor, and two pins for seat position sensor. Makes a pretty clean install. No need for adapter harness for seat heating, and no other extra unused wiring is left under the seat.
Seat with occupancy sensor using existing opening and with Seat Position Sensor wired into main plug.
Main Plug with Seat Position Sensor.
All you need from the donor passenger wiring harness - this is for the Occupancy Sensor.
The only pins needed for the Occupancy Sensor.
The only wires needed for the Occupancy Sensor.
The sensor harness taped up and all three new pins added to the existing main connector.
Seat ready to be installed.
All done.
No CEL or Airbag Light
All done.
cbracerx (09-12-2022)
#261
With some of the bars designed for full buckets, I've seen Sparco/Recaro track seats mounted too high, resulting in very poor belt angles.
#262
Is that also a Cantrell harness bar? It looks to be the right height for these GT2 buckets, as Schroth requires the shoulder belt angle to the bar/attachment to be level or up to minus 20 degrees when wearing your HANS / HnN restraint.
vantage (09-14-2022)
#263
Great work on this. I am trying to get a 991 sport seat into my 996 and was hoping someone here could help with confirming or finding errors on my diagram.
I am pretty confident about everything on the 996 side, but I thing some things are not correct on the 991 side, especially the seatbelt parts, since I do not see any wires going there.
#264
For California residents who imported a bucket seat from carnewal or other place:
Has anyone gotten hit with a sales / use tax bill from California? I just got a letter asking to pay 9.5% use tax (separate and apart from the 3% import duty). Seat was imported in July 2022.
#266
#268
I'm installing harnesses on my 981 with the GT2 bucket seats. Need some help with the lap belts.
I have the schroth GT3/GT4 bolt kit (below).
I'm not able to figure out the ordering of the washers. I tried the following setup:
Seat | Porsche specific harness end | small washer (bottom) | tiny sleeve with factory belt/buckle | bolt.
If I add the big washer that goes over the sleeve/post, there isn't enough space for the factory belt. If I omit the washer (as above), the harness ends up with some play.
What's the correct order? Thanks!
#270
Agree. I think worst comes to worst I’ll see if I could get a custom made bracket that sits lower.
I’ll reach out to Mooty to see if there’s anyone I could meet to sit in the car. Thanks!
That’s a bummer but good to know I guess. It sounds like the only gating piece is the occupancy sensor warning (which to activate the airbag). Again, I presume you are right on about the US PIWIS not able to clear the code. Again, I‘ve seen folks on the forum taking delivery of the T with the GT2 bucket seat but they are all in Europe.
