Girodisc Rotors
#107
I've never heard of anyone doing it but I've never heard anyone say physically it can't be done either. I had a 997 GT3 MC put on a Cayman R which was a popular upgrade at the time and eliminated a similar condition with the braking system on that car.
#108
The brake pad certainly is part of this but I think the issue lies elsewhere. It's like that on the street and on the first lap out on track. I owned a GT350 that I tracked a lot and had the chance to drive a GT350R on track Monday. The GT350 has a much firmer pedal. The car I drove had the stock brake pads which I think are similar to the GT3 pad compound. I tend to think RDCR is onto something about the assistant and booster used on the car. Anyway the brakes work well I just prefer a firmer brake pedal earlier in the pedal travel.
#109
#110
My understanding is the 991.1 GT3 master cylinder is not a simple drop in upgrade like folks say on a 997.2. Supposedly you have to replace the whole system to move to the GT3 master cylinder. So, I stopped looking into that option. That didn't seem like a practical option.
CarreraFahrer (12-28-2019)
#111
Just a quick update. I've now done 6 track days with this setup and it works very well. I was concerned about the balance of the braking using the OEM GT3 front brake compound with the OEM C2S rear brake compound and there are no issues. Because I'm not doing as many track days as I was in my Mustangs I'm going to stick with the stock compounds. I'm going to replace the rear brake pads now and will do so with the OEM compound.
#112
#113
I agree that the Girodisc rotors are super durable. I didn’t get a chance to measure the pads but I can say that it’s noticeably much less wear over stock. Here’s some shots of the surface temps after a session at Laguna during the summer. Front is Girodisc and rear is stock, both running Pagid RS29 pads.
Front
Rear
Front
Rear
#114
A couple of things to note on your temps above. The front rotors have much better brake cooling ducts and if your TC wasn't completely disabled it uses the rear brakes to control the car which can quickly overheat the rear brakes.
koala (06-07-2020)
#115
CarreraFaher...the mushy feeling is the pad...since you’re using Endless brake fluid...highly highly doubt you’re boiling fluid. The gt3 pad is still a street pad and the gt3 has way better brake cooling than a Carrera...so you rotor and pad is getting hotter and the pad gets mushy feeling. Boiling the fluid pedal will go to the floor.
I suggest Pagid RS29 Yellow for Track use pads.
I now have a Brembo GTS BBK 380 front and rear. If you want to know what the unicorn pad is, quiet on the street and epic on the track, best feel, superior bite. Endless ME20. I run Endless MX72+ on rear, and they aren't wearing at all. The MX72+ have never made a single sound ever. The ME20 on front occassionally on the street make the slightest little squeal. But it is less than the stock brakes made, and not as high pitched, so it is nothing.
But for the awesome stopping power they are epic. I also run Castrol SRF. Never boiled it once. I boiled the stock fluid on the street.
#116
I tried Pagid RS29 Yellows and they squeeled like a banshee.
#118
That is not correct. Why would they lose their effectiveness? I've taken many sets down to the backing plates and never had any issues. They are good as any pad on the market, just look at all of the race teams that use them.
#119
I have no idea why. I’ve never tried them. I read about that somewhere here on Rennlist or another forum. I actually have a set. A bought some spare Girodisc Rotors from a guy here in the market place and he included a few extra sets of ferodos and pagids. I like ferodo, but once I go through them, I plan to try the pagids.
#120
I swore I wouldn't track my 991.1s, but while my turbo was apart did, and see the appeal for further distance tracks where a comfy AC seat can be nice!
After tracking my 991 a couple times few times and realizing new stock/Textars are good for about 3 hours of track time, the Giro A1-032/GT3 pad seems the way to go.
Or, 2 sets of Textars from FCP and their lifetime warranty, lol
With a pair or front 997.2 turbo s Sebro rotors costing $350, has anyone run them vs the Giros?
Maybe I'm missing something with the OE 997.2 turbo S 350mm rotor not having a reduced hat size like the Giro A1-032 so it won't fit, or do they work fine too?
Also, since I've been running the same Brembo HTC64t fluid for over a year, it's time to bleed and I was thinking of new steel brake lines too.
What are you guys using for brake lines that you feel are better than just a fresh set of OE rubber lines?
