Girodisc Rotors
That said, I am also probably being a bit lazy also: I have Tarett brake caliper studs and did not feel like swapping them out for longer studs that will allow the use of spacers. Time is really short these days so I thought it would just be easier to use Sebro OEM-size rear rotors for now.
I upgraded my rotors with GiroDisc almost 1 1/2 years ago. I also upgraded the front pads with GT3 pads. I didn’t like the dust the OEM pads put out so I elected to try the Carbotech pads. I must add there is minimal dust and great stopping power.
GT3 Front Cartotech Pads vs OEM Pads.
Greater Surface area on GT3 Pads
I installed the Carbotech pads on the front & rear. I elected the Carbotech 1521 pads which are for street use only. I also pre-bedded the pads and rotors and to date i have no squeaking at all. I’m very happy with the results: very low brake dust, zero squeaking and great stopping performance. I also would like to add I replaced my OEM brake lines during my two year brake fluid flush. I used the steel braided lines and they look great and perform beyond my expectations. I have noticed a firmer Brake peddle vs the OEM lines.
Front Brake Line
Rear Brake Line
Techna Fit: Red Coated Steel Braided Brake Lines
Front Brake Line
Rear Brake Line
I've been wondering if it's possible to use Tarett studs with the Girodisc setup on .1 GTS. I guess it would depend if Tarrett has the proper lengths that would work given the spacers and also if the calipers will reach over a stud setup given the constraints of the brake lines. I had the stud kit on the GT4 and it's just way better then the OEM bolts.
Member @RonD mentioned this mod to me a while back and although I haven't pulled the trigger on this I'm planning on doing so soon. The setup using the A1-032 rotors allows you to use any GT3 pad not just OEM. As posted above they have a larger surface area which should facilitate better heat dissipation. I also used a caliper stud kit, similar to what Tarett sells, on my GT350. Radial mounts with studs is the way to go if you're tracking a car.
BTW I've run Pagid RS29's on by Boss 302 and GT350 and didn't have any issue with brake squeal on the street. Neither car was a DD. I've also ran the pads down very thin and didn't notice any drop off in performance. I've run thru about 10 sets between the two cars.
I could not use studs on the rears because the brake lines didn't have enough slack to get the calipers around the stud. This was no big deal as the rear brake calipers line up well with the uprights, it was the fronts that have an odd funky alignment that was begging for a crossthread.
BTW I've run Pagid RS29's on by Boss 302 and GT350 and didn't have any issue with brake squeal on the street. Neither car was a DD. I've also ran the pads down very thin and didn't notice any drop off in performance. I've run thru about 10 sets between the two cars. I'm probably going to try the DS2500's because everyone likes them.
I used ds2500 on GiroDisc front and rear on ,y 2017 GTS...they work great on the street but didn’t last at the track....Sebring...they left build up on rear rotors and after a track day and couple morning sessions next day they were toast. They got mushy half way into a session too. Sebring is hard on brakes and I’m keeping up with most new gt3’s passing some with my gts so we are cooking right along. I next tried the Ferodo ds1.11 and they worked much better on track, squealed badly on the street but didn’t seem to last as long as Pagid rs29 yellows....
it’s a constant back and forth of compromise between what’s good for the track or street, isn’t it? I drive my car on the street, but, lately, with the rollbar, seat and harnesses, it has become an overweight track car that I sometimes use on the weekend. I say overweight because I refuse to gut it despite my best intentions. It’s a base 991.1 carrera and has plenty of everything for the track. The brakes and handling are incredible. I find myself keeping up if not driving better than corvettes, but looking for longetivity with the brakes is a challenge. Hoping girodiscs and bigger pads help. Will switch to a better race pad when I outbrake the new equipment.
Giro's, tweener pads like the DS2500 or OEM GT3 and maybe brakelines (to help solidify the pedal?) would give me a little more confidence / make the occasional trackday more enjoyable and hopefully keep the pad noise livable on the street.
