Glazed pads and rotors
Hello
I purchased a pre-owned 2017 4s with standard red caliber steel brakes.
I feel that the stopping power is not as immediate or strong as the brakes should be.
I suspect the pads or the rotors or both have some glazing as the braking can best be described as initial brake-trailing, then moderate braking. The brakes don't feel sharp as they do on my BMW for example upon depressing the pedal.
Pedal is firm.
Is there a best-practise procedure to remove the glazing that others have found successful?
Is there a way sharpen up the initial brake engagement ?
I have tried some hard driving on back roads with an emphasis on braking to see if that would help it did not... I have tried a series of high speed stops (80km to 20km and repeat 4x) which also did not work.
In summary I would like better initial bite when pressing the pedal.
Looking for some helpful suggestions.
Thanks !
Pedal is firm.
Thanks !
RE-bedding your brakes would be the first step.
Do 12+ high speed stops ( 110km to 20) back to back till the brakes are very hot.
That should remove the glazing.
If that doesnt work, then you might need new pads or a street/track pad that will have more bite.
Sounds like you’ve already taken the right steps to no avail. Do you know if the pads are stock or aftermarket? The prior owner may have changed the pads out for low dust pads. OEM pads give good bite when cold and work well up to fairly hard use, but give off a lot of dust. Maybe the prior owner traded bite for low dust by swapping for low dust pads.
Great point !
I will pull the pads out this weekend and check to see if they are Porsche branded brembo or something else.
Does anyone know off hand what torque the callipers should be tightened back to once released ?
Originally Posted by mgordon18
The 2 big bolts for the calipers? For a 991.1 S it's 63 ft/lbs. I assume it's the same for 991.2, but not 100% sure.
I found similar information on the diy brake change thread - where on the 991.1 the torque was 63ft/lbs.
It will be interesting to see if the torxs bolts have been marked up from tool use to indicate there was a change made from stock to low dust pads.
63 ft/lbs but technically those caliper bolts are 1 time use per Porsche Workshop Manual. You dealer will have new bolts
This would be my first step. I don’t think what the OP did was sufficient to get heat in them. I’d want to be able to smell them and then I’d feel I had them at temp.
Received 3,883 Likes
Yes caliper screws stretch and you are supposed to replace them each time if you go by the book.....I'm pretty comfortable re-using them myself, I think one year I did like thirty-five pad/rotor swaps for track days - that's a lot of caliper screws!
Some folks I know use a dab of blue loctite but I've never used it.
Originally Posted by 3Series
LOL. That's a lot of swapping in a year....but I hear ya, I used to do the same thing. I don't swap anymore but I used to change the bolt every two years, after about 20 removals.
How did the rest of the car hold up from such use /abuse !
Originally Posted by Pep!RRRR
How old is the brake fluid and have the brakes been bled? Lack of pedal firmness suggests a problem with the fluid.
