Why so few sport chronos in manual trans cars?
#31
Wow. There is a lot more going on than just that. Let me count the ways and I am sure I am missing some.
1. Rev matching
2. Improved throttle mapping
3. Dynamic engine mounts
4. relaxes the point at which PSM engages
5. G-force meter
6. Clock
7. Laptime stopwatch
8. Sport screen on PCM with lap comparisons
9. ability to download car/engine data to excel for analysis or pairing with video
10. Upshift indicator
1. Rev matching
5. G-force meter
6. Clock
I am curious though what the throttle mapping differences are with SC compared to a MT car in Sport mode (more or less how I drive the car every time).
I assume the shift points in a PDK are probably altered with SC - but for an MT, what does SC do over and above engaging the Sport button in a non-SC car?
#32
Yeah, called out and you are right - a bit obnoxious. It's a result of my long-time friend repeatedly telling me that heel-toe is a requirement for good driving and that I've gone soft.
#33
https://rennlist.com/forums/991/1041...ent-boost.html
I was planning on ordering a C2, and would not have ordered SC. My car fell into my lap, and it has SC which is great because knowing what I know now would have had me ordering the wrong car.
#34
1. Rev matching
5. G-force meter
6. Clock
3 is a worthwhile upgrade in my book
4 is nice if you want to drift your 911, or have reason to be sideways often; otherwise, PSM is very good and unobtrusive
1 and 6 are downsides in my view, and only defeatable by making other compromises
2 "improved" means sharper, which only makes the car feel faster/more responsive and actually makes it a bit trickier to drive smoothly when it matters most
The rest don't hurt anything, but don't do much for me, either. YMMV. You do get Individual mode, but it's a pity that it doesn't offer more individuality—using that giant PCM screen to configure one's preferred steering, damper, throttle, rev-matching, etc preferences to a tee. The question is whether #3 above is worth the full price of SCP, to me. I decided it was wasn't when I spec'd my car, and now kind of regret that decision.
#35
I have SC in my manual 991.2 4s and I love the rev matching in sport mode. It is a relatively cheap option. Also love the analog clock.
#36
Its almost funny reading the comments about "more aggressive" throttle response. Does anyone actually believe that? If you do, sorry, wrong. Throttle response on ALL these cars, even with SC, is seriously dumbed down. Slowed. As in the slow kid who just can't keep up. So its not "more aggressive" its actually just a little less artificially attenuated. Partly this is Porsche trying to cope with onerous regulations. A lot though is the reality of the vast majority of owners being utterly unprepared for the reality of 400+ horsepower. They want to go fast. They do NOT want to have to actually acquire the skills needed to go fast. Very extremely annoyingly aggravating, the way the few have to suffer for the majority this way. Especially since its mostly the very vocal minority who think its their glorious clutch pedal that denotes their driving superiority, even as they prove the opposite by not appreciating this valuable option. Sad.
Also makes me wonder, if fast throttle response "when it matters most" is so bad, how much they slow it down in F1. Right.
#39
Received 2,279 Likes
P.S. I like the clock too. You can make the needle go around fast when resetting the lap timer.
The maximum boost pressure (13 psi in the case of the base, and 16 psi in the S) is achieved only in S+ with the .2. Also, in S and S+ the turbos are kept "hot" that is they are they are sometimes making 1 psi of boost with light throttle, whereas is normal mode there would be no boost at all. I suspect this intended to reduce lag.
That's another good one that I missed. It comes with the **** on the steering wheel instead of buttons and adds I mode.
#40
I suspect that F1 cars have very linear--and rapid--throttle response.
Also, I'm curious about this notion that the 991.2s only make peak boost in Sport+ mode. Since non-SC cars don't offer Sport+, that would suggest that they evelop less boost and make less peak power than the SC cars. Porsche does not indicate this in any of the specifications so I'm dubious about this peak-boost-only-in-Sport+ notion.
#41
If I'm not mistaken, on the new T model ordering sport chrono isn't tied to anything but a track app. The car comes with everything that is usually tied to the dash wart as standard, and that's a good thing imo.
#42
Porsche should definitely clarify this question. If the boost is truly higher in Sport+ mode, I would think that it should be advertised as a marketing tool for SC.
#43
And while it might be "awesome", more awesome is doing it yourself and getting it right.
#44
2 grand for a useless wart on your dash? Not for me. I deliberately left it off. If you can't properly heel and toe for yourself you're missing half the fun.
#45
Received 5,413 Likes
