991.2 handling of Targa gts vs 991.2 Targa 4s
Old 05-25-2018, 11:51 AM
casaforte9
casaforte9's Avatar
Default 991.2 handling of Targa gts vs 991.2 Targa 4s
My colleague is interested in Targa but considering a 4S with leather etc ( he is not an aclantara fan like me ). he does not like black wheels and i believe with GTS you are stuck with black wheels , correct?
With Rear wheel steering on both cars, is it fair to say Handling around bends and curves should be very close with targa GTS having little more urgency due to Torque/HP increases?
In summary what are the main handlng differences between the models if visual looks are not cosidered
Any one who made the switch( 4s to GTS targa or 4s cab to gts cab or the the other way around ) can provide input please ?
Old 05-25-2018, 03:03 PM
dhirm5
dhirm5's Avatar
Received 1,451 Likes on 798 Posts
No input on the actual question, but you can order a GTS with wheels painted silver or body color; this forces you into the Carrera S wheel (instead of the Turbo S), but it is an option, and looks great.
Old 05-25-2018, 03:11 PM
casaforte9
casaforte9's Avatar
Dhirms,
O yes , that is an Option , never occurred to me that painted silver is a 0 cost option on S wheel if black wheels are not preferred - Thank you
Old 05-25-2018, 03:18 PM
Needsdecaf
Needsdecaf's Avatar
Received 2,528 Likes on 1,575 Posts
No difference if similarly equipped from a performance option standpoint. The GTS will just have more power.
Old 05-25-2018, 03:42 PM
casaforte9
casaforte9's Avatar
I read somewhere but do not remember which magazine article / online that the GTS over S has
A) Better steering feel
B) PSE is little louder ( side effect of less insulation , maybe ?) PDK is more precise/faster- not sure if this is true and what precise means in PDK box?
The below was also said which i am inferring that it is for RWD S vs RWD GTS -
A) Wide body provides less body roll and better grip at the rear
​B) Wide Chasis uses the extra power and torque better -more traction
Old 05-25-2018, 03:45 PM
dhirm5
dhirm5's Avatar
4S is also wide body -- other points may be true.
At risk of stirring up the hornet's nest, I'll point out that GTS is a more desirable model, and will hold it's value better on the resale side, over 4S, all else equal.
Old 05-25-2018, 04:00 PM
DaveGee
DaveGee's Avatar
I bought a Targa C4S instead of a GTS for the same reason as your friend. And I wanted a specific interior and specific wheels. I also ordered it with the PowerKit, so essentially a GTS to my specs. Difference in handling vs a GTS? None. I’ve driven both.
GTS better resale? Who knows? Bought it to drive it, not sell it.
DaveGee
Old 05-25-2018, 04:21 PM
uury
uury's Avatar
Also, if the color of the centerlock wheels is a concern, it's easy to paint or refinish them (several here have done that).
Old 05-25-2018, 09:15 PM
Andial
Andial's Avatar
All Targas are AWD. The 4S is sufficient w/ the Powerkit and other upgrades.
Old 05-26-2018, 08:23 AM
JPMD
JPMD's Avatar
DaveGee
I'm all for saving money and benefit from better resale but in this case I also built Targa4S + powerkit vs GTS. Its my daily driver and had fun building to my specs and couldn't be happier with the result.
Old 05-26-2018, 11:02 AM
DaveGee
DaveGee's Avatar
Great minds, yada, yada, yada...
DaveGee
Quick Reply: 991.2 handling of Targa gts vs 991.2 Targa 4s
