Mirror Wind Diffuser for 991's, reviews?
Old 05-18-2018, 03:05 PM
MoreSpeed
MoreSpeed's Avatar
Question Mirror Wind Diffuser for 991's, reviews?
Anyone try these?
https://www.suncoastparts.com/product/PK9X1MIRROR.html
Worth $100?
Old 05-18-2018, 03:12 PM
MoreSpeed
MoreSpeed's Avatar
Originally Posted by MoreSpeed
Looks easy to install... AWE_Porsche_Landing_Page_Foiler_.pdf
Old 05-18-2018, 03:41 PM
awrryan
awrryan's Avatar
I have them. They work on both the highway and on the track. Worthwhile, in my opinion.
Old 05-18-2018, 04:40 PM
9914s
9914s's Avatar
Yep they work as advertised
Old 05-18-2018, 04:45 PM
porshah
porshah's Avatar
I have them as well. Especially great since I have GT3 mirrors.
Old 05-18-2018, 04:46 PM
JFerraro17
JFerraro17's Avatar
Bought, tried, sent back.
Couldn't get them to fit tightly along the bottom...nowhere near as tight as the OEM. Tried multiple adjustments and re-installation (always assume it's me). And really, there's only so much "adjustment" you can do. Passenger side fit better than driver's, but still not OEM tight...couldn't get past the look. In the end, sent back for refund, minus shipping. Customer service at TAG was great, btw.
Honestly, although I've driven less than 500 miles, I don't really feel like the buffeting is pronounced. So coupled with the fitment in my case, not worth it.
Old 05-18-2018, 04:48 PM
Illini675
Illini675's Avatar
Does anyone have experience with installing these on "early" 991's? Based on the Suncoast reviews, it looks like there are some major install challenges associated with the early models.
Old 05-18-2018, 04:52 PM
Phaedrus.
Phaedrus.'s Avatar
Careful with the install. There is an "easy install" and an "incredibly intimidating and complicated install" (my description). I purchased a set of these recently, and the instructions call for you to remove the interior trim piece where the wind diffuser gets installed. If you see a screw there - congratulations, you get to follow the easy route. If you don't (like in my case) the install is far more complicated. If you look at the link to the install instructions posted above, and scroll down to the "hidden screw" link, that will open the PDF for that install. Maybe I am just easily intimidated, but when I realized my 2014 C4S has the "hidden screw", the job got moved from my TO DO list to the TO DO list of my local independent Porsche mechanic.....
I have no doubt that these will help with the buffeting, just wanted to point out the two possible install paths....
Good luck.
PS - I'd be interested in hearing from anyone that has done the complicated install - is it as bad as it seems from the instructions??
Last edited by Phaedrus.; 05-18-2018 at 04:54 PM. Reason: edited to add year of my car in response to post above mine
Old 05-18-2018, 05:02 PM
daberlin
daberlin's Avatar
Another Plus vote. Easy to install and work as advertised. They do make a substantial difference going down the road with the windows down.
Old 05-18-2018, 05:03 PM
daberlin
daberlin's Avatar
Good luck.
Very interesting that I too have a 2014 C4S and had the visible screw path, thus 'easy'.
Old 05-18-2018, 07:04 PM
991carreradriver
991carreradriver's Avatar
I think the major install procedure change in late 2013. I purchased and installed on my 2014 C2, took them off put them on my 2016 C2, took them off and put on my GT3. Do you think I am happy? On the track, I can hear someone in the right seat without a headset and that is quite an accomplishment in a GT3 with a GMG racing exhaust.
Old 05-18-2018, 07:09 PM
s4one
s4one's Avatar
Works for me, I had to do the hard instillation but it's pretty easy. You actually don't need to remove the door all the way. Just pull it off and let it rest on your leg or feet.
Pretty simple.
If you drive with the windows all the way down, you'll noticed a huge difference over 90+ mph
Old 05-18-2018, 07:20 PM
vodkag
vodkag's Avatar
Yes i am thinking about it too. But i have an early 2012 so i prob need to go through the complex install. Which is not too bad.
but at 100 bux.....i think i can make something for less. All there is to it is a lip that curves out. Just need to sit down one day and figure out a solution that looks decent and prob without removing the door panel
Old 05-18-2018, 07:42 PM
991carreradriver
There is a "stick on version" made by another manufacturer. Research the threads and you will find it.
Old 05-18-2018, 09:20 PM
USGooner
USGooner's Avatar
I got mine from Suncoast. Easy 30 - 45 min. install. They work great driving around town, at highway speeds and on the track. No buffeting issues at all.
Quick Reply: Mirror Wind Diffuser for 991's, reviews?
