Mirror Wind Diffuser for 991's, reviews?
They work great, just be careful with the small screw not to break it. Whether you need it depends on whether the wind buffeting bothers you. For some reason each car, and each persons ear, is different to the buffeting.
Got mine from Suncoast, and the same set are now on my 2nd 911. Love em! Simple installation, unless you have an early 991.1, which requires the entire door panels to be removed. Not sure when Porsche changed this part of the 911 door design...
Works for me, I had to do the hard instillation but it's pretty easy. You actually don't need to remove the door all the way. Just pull it off and let it rest on your leg or feet.
Pretty simple.
If you drive with the windows all the way down, you'll noticed a huge difference over 90+ mph
Pretty simple.
An observation I've had is that I don't feel as compelled to install this on my newer 991.2 with Sport Design mirrors. I think they substantially change the flow and get rid of the beating problem if both windows are down, at least at legal highway speeds. With the standard mirrors the beating was certainly a problem.
