Centric Pads
Not sure who that is directed towards, but I acquired my Carrera pre-owned with factory brakes that had some miles on them. No amount of performing bedding procedures would alleviate the squealing. In fact, early 991 base front brake pads were replaced with a revised part number due to the propensity to make excessive noise. Can't find the link to the campaign details at the moment.
I've an appt w/ the dealer on this next week. We'll see. I will try to blast the brakes (both in washing and deglazzing them) this weekend to see if I can get any improvement.
I use Centric too. You just can't beat them for regular street use. They are quiet, effective, brakes well during emergency when cold, less dust....what more could you ask for. Just don't use it for tracking.
OP, you may also want to reapply some brake pad lubricant if you have the time/patience to take the brakes off. This helped with squeal on a previous care and I definitely applied some when I put in my new 991 brake pads/rotors.
Yeah, I've had success with that on previous vehicles. When I first bought my car, I asked the service advisor to clean the brakes and relubricate in an attempt to alleviate my squealing. It didn't help, and they gave me the same old story about noise being inevitable. I entirely understand that noise will occur due to the design of the brakes, but I think I proved my suspicions correct by getting rid of the noise with different pads and new rotors.
I'm considering replacing the stock pads on my 991.2 4s with the Centric pads for the reasons mentioned here. Do the brake pad sensors also need to be replaced when replacing the pads?
The last time I looked I didn't see any ceramic pads for 991.2 S models. Are there some out there?
I had previously seen that they make the ceramic pads that fit the rear but not the front.
None of those are their low-dust ceramic pads... those are metallic and semi-metallic. They are fine replacements, just not the low-dust ones I'd switch over for. You may be seeing the ones for the ceramic discs, but those are the pads for ceramic rotors, not the iron ones.
Edit: After going back and reading through the thread it was clear that these were semi-metallic since that was discussed. I guess I forgot over time and needed a refresh. Oops.
Personally I think ceramic pads are ok, but there are pros and cos. They do last a long time and produce less dust and are fairly quiet. I've used them and I found out there is one con that is significant enough for me to change it out. They are not effective when wet or cold. The morning hours when temperatures dip, or when doused with water after a car wash, the brake pads are not effective at all. This is detrimental on normal street driving where you don't have the luxury of heating up your brakes before going on a hot lap. On the street, when you need your brakes, you need it right away and when you are caught with stone-cold brake pads, the brakes pads just won't bite or grab at all. This adverse effect only last a second or two, and then the brakes bite and the modulation of the brake pedal recovers. However, that sensation is nerve wrecking and I didn't like it at all. Then I switched to Centric pads and it made a huge difference. I like the brake modulation feeling and the effectiveness of it when the brakes are still stone-cold. That being said, those are not for track use, not the ceramics either for that matter.
Basic Sponsor
EBC
-Josh
-Josh
Your #1 Dealer for Aftermarket Performance Products
BC Forged / Soul Performance / Akrapovic / Bilstein / HRE / AL13 / CSF + more
Orange County, CA
Email: info@merakiautoworks.com
Text/Call: 213 394 2886
Website: www.MerakiAutoworks.com
Orange County, CA
