View Poll Results: How does this compare to your PPF install?
Voters: 63. You may not vote on this poll
Is this a good protective film wrap/job?
#31
It' an either or proposition. Either you put up with the precut not wrapping under the edges OR you allow someone to come dangerously close to your paint with an exacto knife. There was a horror story about a guy getting his brand new gt3 cut up due to the second option gone wrong. The precut just keeps paint from getting chipped so it does its job. Water based Paint from Porsche today is like 3 miils thick so without it your are hosed.
#32
That's a perfectly acceptable job for a pre-cut unwrapped PPF. Wrapped PPF, where you cannot see the edges is more expensive and considerably more difficult to apply. Some installers will offer both, others will just do one or the other but may not mention the other option. Unwrapped PPF is more noticeable on white than any other color. I can clearly see the line across the hood on my silver 4S but I'm fine with it. (better a line then road rash)
#33
Frenzyy... after all the feedback, curious what your plan is.
#34
Very poor Pattern. I just had my 2018 GTS full wrap. No boarders like that. I paid a lot more. The guys did say that they had the pattern adjusted. The Original pattern sounded similar to what you got. So they extended the pattern so it could be rolled basically everywhere. I was unsure I I got a good job, until seeing yours. My car doesn't have any margins anywhere.
#35
#36
Premium Sponsor
when it comes to bumpers, yes there will be seams, but the cuts are computer done and symmetrical.
the most important aspect of the installation, whether it’s custom, semi-custom, or pre-cut, is the installer...because if he/she is unskilled, you DEFINITELY don’t want a custom installation.
with custom installation, you are relying 100% on skill of installer and his/her blade
#37
Premium Sponsor
As for pricing, $1800 usd, at least in CA, gets you wrapped edges by most shops depending on coverage. We typically charge a bot more because we’re psychotic about wrapped edges, so on 991.2, we actually removed headlights and we wrap the lights also.
It’s important to research this stuff and I’d also recommend sending photos of the level of work you’d like done, based on seeing threads like this and others here on rennlist, then show those photos to your installer. This will set the expectation and both of you will be aligned with the final result.
if the installer did not explain difference of wrapped and unwrapped edges, and give you your options, then he/she should do better on initial consultation. I’m not sure if you told him your expectations, so I cannot make any assumptions.
but now that you know, the two of you should work something out. As many have mentioned, over time, those edges on a white car will show signs of dirt, and you’ll be replacing the pieces.
here’s a typical semi-custom level of work at our shop
https://rennlist.com/forums/991/1038...nano-tint.html
#38
Here’s the good thing about PPF, even a mediocre install protects the car.
If you can get it fixed by the original installer go for it. If not live with it for a while and then find a top notch installer to do it again. Ask for edges to be wrapped.
I have Suntek now, had Xpel several times before. Both great films with similar properties.
#39
^ this.
I am still on the fence about getting PPF on my car when it arrives. Didn't have it on my first 991S. My second 991S had it on the front all the way back to (and including) the side mirrors, from the previous owner. The edges weren't wrapped around the fenders, etc., but they were a LOT closer to the edges of the body panel than in the OP's photo. You couldn't tell it had PPF until you were up close to the car.
#40
I was on the fence about getting PPF for my brand new GTS as well. However, right around my 47th trip to the garage to stare at it the first night in there, I thought "who the hell do I think I'm kidding?" There was no way on God's green earth I was going let that beautiful Carmine Red front get chewed up.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#41
I was on the fence about getting PPF for my brand new GTS as well. However, right around my 47th trip to the garage to stare at it the first night in there, I thought "who the hell do I think I'm kidding?" There was no way on God's green earth I was going let that beautiful Carmine Red front get chewed up. ![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#42
Looking at it I'd say that the margins are too wide and not applied congruent with adjacent panels. Also some of the corners do not appear to be cut from a plotter but rather by the installers xacto knife. I would disagree about the edges catching dirt however. Just keep the car clean, polished and waxed and you'd be fine. Isn't that the level of condition we all want our cars to be maintained? Otherwise, why even get PPF?
