Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
#467
A huge shout out for ACG Automotive in San Diego. Girard took especially good care of my 991.1S when installing this fabulous CarPlay kit from NM Automotive in the U.K. (Thank you Nick - you are GREAT).
Now, my 2015 Cab has a full CarPlay interface with Waze, Podcast, text messaging, etc. it even comes with a Backup camera. It’s like having a brand new car. THANK YOU - Nick & Girard!!
#468
#469
Search "standoff screws". I bought this kit:
It doesn't have a 25mm raiser if thats the size you want. Depending on which satellite radio you have (some are thinner than others), you will need a different riser length.
#470
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Wow, I had a huge brain fart......I built computers as one of my first jobs 20 years ago...I probably have these in a parts bin in my basement.
#471
Try this link.
https://www.amazon.com/Electronics-Salon-Male-Female-Stainless-Assortment-Raspberry-Pi/dp/B072N84VM3/ref=pd_sbs_60_2/130-5124109-5045512?_encoding=UTF8&pd_rd_i=B072N84VM3&pd_rd_r=15c58ef2-7e46-11e9-b428-7d17b7108ea6&pd_rd_w=Kbd96&pd_rd_wg=XGdlR&pf_rd_p=588939de-d3f8-42f1-a3d8-d556eae5797d&pf_rd_r=76RVN7WFZS560F69VW49&psc=1&refRID=76RVN7WFZS560F69VW49
#473
Wireless CarPlay installed, works perfectly
I've got mine installed on a 2013 911. I don't need the SiriusXM so didn't even bother with risers, works great whether iPhone is concerned through USB or wifi. Ordered from China, local audio shop installed it. Let me know if you need the details.
#474
Hi All! First post on Rennlist. Did the CarPlay retrofit install on my 2016 Boxster, here are my notes and a few follow up questions! Would appreciate folks weighing in.
- Kit: is the Joyeauto PCM3.1 with Wireless CarPlay, about 400$ USD shipped express to California on Aliexpress. Kit came nicely packaged and all components seem very high quality. Wiring harnesses nicely wrapped in fabric tape etc - looks automotive grade to my untrained eye.
- Car: Installation into a 2016 Boxster: Pulled trim pieces on each side of the shifter console. Requires a lot of force, feels like you're going to break the car, but they do come out, straight horizontally towards the doors on each side. After that, four screws to remove the PCM unit.
- First test: Connected everything together using included wiring chart - it is fairly fool proof EXCEPT one important item not noted on instructions - their main wiring harness pass-through does NOT include the two fibre optic cables, so the connector for them must be removed from the factory wiring block and moved over to the pass-through block they provide, such that the fibre cables are still going straight into the back of the radio. Didn't do this at first and the car both had no audio and would not change audio source.
- Satellite Radio problem: As mentioned by some, after removing the satellite radio board to make room for theirs, FM and AM radio no longer have sound. I've ordered the longer stand-offs - Question: I imagine I will have to put a "hard" bend in the ribbon cables in order to fit their board with longer stand-offs. Is that a no-no? It feels like it will really tight with both boards... Or is there a way to get FM/AM sound back with the satellite radio removed? That would probably be my preferred choice...
- Backup Camera problem: My factory backup camera no longer turns on when shifting into reverse with their kit installed. Their kit has an option for their own camera (for cars that didn't come with one) but even after making sure the DIP switch is set for "Factory original" backup camera, it doesn't work. I've emailed them asking for help on this point.
- Final Re-assembly: I still need to get the longer stand-offs and fix the backup camera before final re-assembly, but in the meantime I am left wondering where to put their box and the big bundle of cables that go to it. Any advice? There seems to be room below the PCM unit, which is basically behind the climate unit, but am unsure of how to get access to that space. Looks like I may have to pull the whole shifter console trim assembly? I'd actually be fine with leaving it in the glove box (where I have it temporarily now) but I can't seem to route the cables in a way where the glove box will close without pinching the wires. As it is now it was easy to get the cables to the glove box, but they pinch when closing.
#475
The kit you ordered from Joyeauto I believe also utilizes the Unichip Integration box as NMautomotive.uk.
1.) Satellite Radio PC Board: You don’t have to remove the satellite PC board. By doing so you run the risk of losing your audio; which is what you stated.
Re-install the Satellite Radio PC Board and verify your connections are firm.
2.) The brass stand-offs you require are M3 x 23mm male to female at four pieces. Remove the four screws that hold the Satellite Radio PC Board secure.
Screw each stand-off where you removed the screws and “ONLY” hand tighten without too much force or you run the risk of cracking the PC board.
You can locate the stand-offs on eBay or Amazon.
https://www.ebay.com/itm/M3x23-6mm-Male-Female-Threaded-Brass-Hex-Tapped-Hexagonal-Spacer-Standoff-5pcs/391411372383? hash=item5b21ef915f:g:STYAAOSwhlZZ0qSf
3.) You don’t need to bend the ribbon connector/s at a sharp 90 degrees. The ribbon connectors will have sufficient room for installation with the correct
23mm male to female stand-offs. There is sufficient room with the Satellite Radio PC Board and the CarPlay motherboard and ribbon connectors.
4.) As for your backup camera not working..... Try this! Go in to the PCM setup mode by holding the [CD-Eject] button for approximately 7 seconds and release. Your screen should display the setup mode. Verify the setting defaults to [Factory Camera/PDC]. Scroll to the bottom of the screen to exit and it should save your setting. To select a specific setting, use the **** to the right to scroll up/down and press to select an option. MAKE SURE YOUR EMERGENCY BRAKE IS DISENGAGED, OTHERWISE YOUR BACKUP CAMERA WILL NOT FUNCTION!
5.) As for the Fiber-Optic cables... As far and i know the kits require you detach the fiber-optic connector from the main harness loom and reattach it to the new harness at the back side of the PCM.
6.) Placing the Integration box and routing the harness loom with the LVDS cable is not impossible, but a challenge. You need to take precautions here to ensure you do not bent or pinch cables. Refer to the attached pictures for reference. Take your time and be patient otherwise you run the risk of damaging your component/s and wiring harness.
CD-Eject Button
PCM Setup Mode
Exit
Integration Box_Under PCM Compartment
CarPlay Motherboard / Ribbon Connectors Satellite Radio Board Mounted below
#476
Also, NM's web site says they won't ship to U.S. How did you obtain it?
#477
I too would be very interested in acquiring a kit.
#480
