991 Turbo wheels on 991.2 GTS
I'll add one more for that 991.1 Turbo S.
So it looks like while the 991.2 Turbo is very close, the 991.1 Turbo is diff in the following:
11.5 vs 12
56mm vs 63
While all have the exact same tire on them, how would that diff be translated to daily use?
Wider sicks out more with there since they are 56 vs my 63?
Did I get that right?
991.2 GTS
Forged "Turbo S III" one-piece center-lock alloy wheels with motorsport-derived spoke design
Black Satin finish with colored Porsche Crest
9 x 20 ET 51 with 245/35 ZR 20 tires (front)
12 x 20 ET 63 with 305/30 ZR 20 tires (rear)
991.2 Turbo S
Two tone finish with colored Porsche Crest
12 x 20 ET 56 with 305/30 ZR 20 tires (rear)
991.1 Turbo S
11.5 x 20 ET 56 with 305/30 ZR 20 tires (rear)
11.5 vs 12
56mm vs 63
991.2 GTS
991.2 Turbo S
991.1 Turbo S
You have to account for:
- Wheel offset (as others have said)
- Inset and outset in light of the offset and wheel width
- Dynamic wheel well fit (a wheel and tire "walk around" quite a bit under various loading)
Why would the recommended tire for the 991.1 rim would be:
11.5 x 20 ET 56 with 325/25 ZR 20 tires (rear)
While the 991.2:
and would the 305/30 fit that rim, it should, right?
While the 991.2:
Folks, someone on here, I believe Rennlister bweile, put these tires on his 991.2 GTS for winter wheels. It’s in one of the winter wheel threads.
https://rennlist.com/forums/991/1024...r-tires-6.html
here you go. Eg911 and bweile put 991 turbo s wheels on their .2 GTS.
The 991.2 Turbo S wheels are pretty darn close. I think they'd probably fit fine.
991.2 GTS
991.2 Turbo S
991.2 GTS
991.2 Turbo S
https://www.wheel-size.com/size/porsche/911/2017/
That website has been invaluable in regards to factory wheel specs.
jets (01-20-2022)
