Do I need Sport Chrono package?
Hi!
Considering my first 911, and I found a 2018 Carrera Coupe with pretty much every feature I'm looking for. It has sports exhaust, which is a must for me because of the awesome sound, but it does not list the Sport Chrono package anywhere (haven't seen pics yet or gone to see the vehicle in person yet to confirm whether it has SC or not, but assuming it doesn't since it is not listed). SC is the only thing it doesn't have listed that I wish it did.
My question is, does the SC package change exhaust noise at all? If I'm not planning to do anything with launch control, do I really need the SC package, or will I be happy without it?
Thanks!
Thanks!
Cobb Engineering provides for programmable MAPS to change the PDK shift points.
Moreover, it can add "Launch Control" which it calls "Race Start"....an uber-cool feature that allows you to rev to 4000-5500 RPM at the stop light and then you take your foot off the brake.
Note: This will allow you to "toast" vettes at least for the first 4 seconds.
Normally you would need the Sports Chrono package to have this capability.
Even then, it's not as flexible as the Cobb approach which can change the RPM settings.
Received 5,413 Likes
You also get dynamic motor mounts with the Sport Chrono.
You’ll be thrilled with the car no matter how it’s configured. Although I’m sure SC is worthwhile to the super aficionados, the rest of us mere mortals probably couldn’t tell the difference between a car with it or without it. Getting caught up in the expensive acronym game is one of the favorite Rennlist pastimes. There’s no end to it.
mustarossa (06-04-2020)
I was faced with the same decision, and for me SC is a must on a 991.2. SC on a .2 gives you:
I might have missed a few things, but for me the convenience of the manettino and ability to configure individual mode are the most compelling. If was buying a .1 I would not care if it had SC or not.
- Manettino dial on the steering wheel to change between O, I, S, and S+ modes. Easier to use than the console buttons.
- Individual mode, which you can use to customize the chassis, transmission, spoiler, and PSE (if equipped). Mine is set to Sport, spoiler disabled.
- The clock (personally I like how it looks)
- Sport Plus mode - Firmer suspension, PSE engaged if equipped, harder shifts, higher shift points, seventh gear disabled, turbos are kept spooled up to reduce lag. Knocks .2 seconds of 0-60 time.
- Dynamic engine mounts that get firmer as you go up in the modes.
- Sports response button that gives you optimal gear, higher shifts points, and keeps the turbos spooled up for 20 seconds.
- Launch control (PDK only)
Received 2,267 Likes
There is a lot to the SC package that benefits manual and pdk drivers.
Also it has the following:
1. G-force meter
2. Relaxes the point at which PSM engages (in sport + mode)
3. Performance screen on PCM
4. Clock with lap timer
5. Rev matching with manual
6. Adds mode switch on steering wheel which includes
Normal mode
SPORT mode
SPORT PLUS mode
Individual mode
SPORT Response button (only in conjunction with PDK)
7. Adds launch control for pdk.
8. Changes the throttle mapping to be more responsive for pdk and manuals and holds revs higher before shifting (w/ pdk)
to the OP: No one needs any option or even a Porsche. but this option is one of my top "wants".
1. G-force meter
Normal mode
SPORT mode
SPORT PLUS mode
Individual mode
OP, another thing I'll add is that if I had to choose between PSE and SC on a 991.2, I would go with the SC. PSE doesn't really do much to enhance sound or performance on the turbo cars.
But on a .1, PSE would be a must for me.
With a PDK car, sport chrono is a must. Has lots of cool features. With a manual, its a waste of $$ - only has rev matching (which you can do manually) and dynamic engine mounts (which you will never miss).
Disagree, I'd say it's a must on 7MT also. Also get the manettino plus shift lights as you get near redline - plus I think it helps resale if that's an issue for you. Lastly - and I'm not sure if this is on non SC cars, but the 7MT has "launch control" also with it. I realize it's basically it holds the revs before you release the clutch, but according to my PEC delivery guy, it's matched to same as PDK, just don't let off clutch too fast.
With or without SC, the 7MT does have an rpm limitation a little over 4K that prevents a higher rpm clutch drop. But I believe this is to preserve the clutch rather than any form of launch control. This limit probably adds a couple of tenths to a manual car's zero-t0-60 and quarter-mile times.
