Door glass out of alignment???
Old 07-25-2018, 04:19 PM
RONGLOS
RONGLOS's Avatar
[QUOTE=randr;14560540]I have seen this on a new GTS - take it to dealer - its a simple warranty job. Don't let them tell you it your fault for closing the door by pushing on the glass window.
It drives me crazy when people close any door by the glass. Finger prints at the least. That is what door handles are for. Old school it definitely loosened up the glass.
Old 07-27-2018, 01:51 AM
mr965
mr965's Avatar
Originally Posted by mr965
Same here. Bringing in to dealer tomorrow.
repaired. One hour job.
Old 07-27-2018, 11:59 PM
Yojeffo
Yojeffo's Avatar
Default Reset Window
TRY THIS.....
To reset window (car must be on):
1) lower the window all the way down and release the switch
2) push the switch down, hold it there for 3 seconds, and then release
3) raise the window all the way and release the switch
4) pull the switch up, hold it for 3 seconds, and then release
5) turn car off and then back onHope this helps anyone else who is having switch problems.
Worked for me
Old 07-28-2018, 12:14 AM
WhipE350
WhipE350's Avatar
My driver side front window regulator was replaced under warranty for this issue. I will save this 'Jingber' technote though!
Old 01-19-2022, 11:58 AM
driven991.1
driven991.1's Avatar
Hello, well my dealer wants to charge clearly over 2 hours and over $ 525 to diagnose. Did it require a new window regulator?
Thanks.
Old 10-13-2022, 08:17 PM
ksozay
ksozay's Avatar
+1 mine is having the same issue (2017 GTS), driver side window is sticking on the rear window when opening the door. Took it to the dealer (Bellevue Porsche) and they quoted me 4 hours to repair. I was dumbfounded...
Going to check with indy.
Old 10-17-2022, 01:17 AM
driven991.1
Folks here as so good at responding and helpful, thought I would share my experience. I took it to the dealer, they charged me $275 in the West Coast. They wrote "removed window seal channel and readjusted driver side door window for proper fitment" @ 63K miles. So either open the window yourself or take it to any EU P show I am sure they will do it for less. They gave me a Panamera rental so I had not much to complain about.
Quick Reply: Door glass out of alignment???
