Must Read If You Track Regularly
Old Oct 23, 2017 | 02:36 PM
991carreradriver's Avatar
991carreradriver
Default Must Read If You Track Regularly
This is a cross thread from both the GT3 and GT4 forum regarding wheel carrier failure and the OEM bolts.
https://rennlist.com/forums/gt4/1030...n-learned.html
Old Oct 23, 2017 | 02:39 PM
R_Rated's Avatar
R_Rated
link is broken
Old Oct 23, 2017 | 03:05 PM
991carreradriver
Originally Posted by R_Rated
link is broken
Repaired!
Old Oct 23, 2017 | 03:19 PM
Bents's Avatar
Bents
Scary...
Old Oct 24, 2017 | 12:54 AM
911happy's Avatar
911happy
Yes, scary stuff. Wonder what does Porsche say about that??
Old Oct 24, 2017 | 01:05 AM
mdrums's Avatar
mdrums
Just so people know...it’s not the wheel bolts but the brake caliper bolts. These bolts are used to hold the caliper to the upright. This happens, nothing new when calipers are taken on and off. The aluminum upright threads can’t handle this.
This is exactly why Porsche ships the cup cars with studs installed into the aluminum upright.
I have caliper studs on my 2017 GTS for this very reason. Makes taking caliper on and off safer and much much easier.
Best part is the studs from Tarett are only $250 for all 4 corners. Well worth it!
Old Oct 24, 2017 | 08:44 AM
991carreradriver
I installed on my last three cars. Aluminum is a step up to using plastic. Disgraceful design.
Old Oct 24, 2017 | 09:35 AM
awrryan's Avatar
awrryan
He may have been running spacers on caliper bolts to run larger size discs. That may have been the culprit if the bolts were not as long as they should have been. Not that switching to studs is a bad idea anyway
Old Oct 24, 2017 | 10:26 AM
Jabs1542's Avatar
Jabs1542
The Girodisks on my car are larger than the OEM, but the kit came with a spacer and longer bolts. I would be surprised that he added a spacer without a longer bolt.
The issue is repeated removal and reattaching the caliper stud into the soft aluminum upright every time you change the pads! I'll change pads 4 to 5 times a year.
Been on the fence about caliper studs, looks like this answered that question.
Old Oct 24, 2017 | 04:58 PM
jwr9152's Avatar
jwr9152
Thank you for posting this. Just ordered caliper studs
Old Oct 24, 2017 | 05:57 PM
BradB's Avatar
BradB
I’ve been using the stainless steel caliper studs for over 3 years now. Makes life easy...and safer.
Old Oct 24, 2017 | 07:46 PM
awrryan's Avatar
awrryan
was going to reach out to you. I know you track yours often and wanted your input. What studs did you buy? Tarret?
Old Oct 24, 2017 | 09:30 PM
BradB's Avatar
BradB
Yes. Worth every penny!
Old Oct 24, 2017 | 10:08 PM
awrryan's Avatar
awrryan
Thanks. And thanks for your other contributions regarding tracking (including those i read about brakes). Much appreciated.
Old Oct 24, 2017 | 10:48 PM
BradB's Avatar
BradB
