One more question on FAL
OK, I've read through all the threads on FAL, and I'm no smarter about it.
I have a GTS coupe with SPASM on order, but not yet locked. I am trying to determine if I should add FAL in order to maintain my sanity.
I currently have a '15 Cayman S with sport suspension (-20MM), so I'd like to get a comparison to that car for reference. The CS is pretty darn low, so I kind of thought the GTS couldn't be any lower or it would be dragging on the ground. Also the PASM Carrera sits pretty high to my eye, so I wasn't thinking -10MM would be any worse than my Cayman S. Of course, I am now questioning that conclusion.
My Cayman S has a narrow sacrificial looking lip just under the front bumper. That lip is 5.5" off the ground. I know what that lip can handle, so I was wondering if a .2 GTS owner could be good enough to tell me the ground clearance of the GTS lip for comparison. I would appreciate any help.
Not sure this will help. Went from a Cayman S to a 991.2 S. The Cayman scraped more than my 911. I did not have pasm on the Cayman but do have it on the 911.
Just went out to garage. The floor to bottom of lip measures just under 6.5 inches.
Thank you both, that was very helpful. I have to admit I'm a little shocked that the GTS is that high, but that info will probably save me a few grand.
My Cayman S gets over speed bumps OK as long as I go real slow. My driveway has a decent entry slope that I can negotiate going at an angle, but I can't get out without just a slight scrape on that non-visible lip. Given it seems to be lower than the GTS, I should be OK without the FAL.
Just remember that the overhang on the 911 is longer than the Cayman, which will make the approach angle steeper than it would appear based just on ride height.
FWIW. I got the FAL and no regrets.
It's been a chin-saver for me, my 997.2 without SPASM was hitting at slow speeds a lot, but my GTS with FAL hasn't. Highly dependent on the type of roads you take, for me it was a no-brainer.
I got it on my Targa GTS and I'm glad I did. I haven't scraped yet, but some of the transitions around me in NY are pretty challenging, so I'm glad to have the peace of mind to be able to raise the car. Yes, I know you can replace the chin several times before matching the cost, but I don't want to be driving around with a scraped up splitter (I already have one good chunk out of from a stone thrown up on the highway) or to endure the pain of hearing the scrape. Peace of mind is worth the cost to me, and I definitely use it.
We've got FAL on our GTS. That was the one option that I held firm on as we searched for our car. The price of FAL is well worth my not dreading/cringing every time I try to pull out of our office parking lot or into/out of other lots. The Hubster tried to convince me that FAL paid for a lot of front lips, but he's admitting that it was a good idea, now that we've got it.
I recently ordered a 911 GTS coupe. I decided against spending the additional money on FAL as my previous Cayman GTS with sport suspension (X73) didn't scrap on my angled driveway (taken at an angle). I guess I'll find out if I was right when the car arrives in about a month.
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
Guys,
very helpful data, thank you all.
I just placed an order for a new build on a 991.2 GTS Cabriolet.
While i was going over the options, i noticed that we get 10mm lowered PASM (not the 20mm PASM sport as the coupe).
Talking to a few people around, they are all saying that the 20mm lowered coupe scraps everywhere and that the Front Axle Lift System is a must.
I was wondering if my build of the 991.2 GTS Cabriolet, with only the 10mm lowered and the front sport facia will require that as well as a must.
Anyone around here that can speak from first hand experience of a 991.2 GTS Cabriolet ground clearance?
My build locks on Jan 8th, so i don't have much time to decide.
I'd rather not spend the $2,500 if i can avoid it, unless it becomes impossible to get in and out of speed bums and garage entrances.
i know for a fact that the 991.2 S with PASM doesn't scrap where i work and live, i just have to figure out the PASM + the GTS front facia.
thanks,
Ben
thanks,
Ben
Guys,
thanks,
Ben
thanks,
Ben
Granted, I spec'd FAL on my .2 GTS during my order...and I use it ALL the time....mainly for peace of mind.
However, I'm starting to think most of the time, I wouldn't have scrapped anyways.
IDK.
I have yet to scrape in first 750 miles.
Totally agree with Blazin.
I LIGHTLY scraped once without FAL in first 100 miles of ownership as I have abnormally steep parking garage entrance. That said I don’t think I’ve needed it very many times in my 991.2 GTS coupe with sport pasm. I felt like I had more issues scraping in my 991.1.
That all said the reason I like FAL is because it has made me lazy. When FAL is engaged I don’t need to be as cautious angling car.
