Front Axle Lift Question
I have a question regarding front axle lift. I may add it to my GTS build, but the answer to this question would have no bearing if I decide to get it or not. Just curious about how it works.
So from what I understand the way it works is at speeds under 35 mph you push a button on the console, and the nose of the car raises by about 1.5". Once you exceed 35 mph, the nose lowers automatically to its normal height. My question is, once it lowers height at a speed above 35 mph, and say you then reduce speed to less than 35 mph, would the nose raise again automatically? Or would you have to push the button again to get it to raise? Thanks
Received 5,410 Likes
I can confirm you have to push button again.
As an aside the manual says do not leave car parked in raised position.
Reading the official description, it seems clear that once you're above 35 MPH, the system turns off, rather than pausing. So yeah, you'd have to press the button again. Also, purely from a UI point of view, you'd annoy far more drivers if it came back on automatically than the other way around.
Scraping the bottom of my car once was enough to convince me that I'd want front axle lift in a custom build, though I wouldn't turn down a car for lacking it. In a GTS coupe build with SPASM, it seems more likely to be more useful.
EDIT: One less expensive alternative is an aftermarket skid plate. Which will save you from minor stuff, but won't help if it's a real bumper-tearing impact rather than just a scrape.
Nevertheless, I think I am going to order it for the GTS. I have occasionally scraped the front lip in both a 981 Boxster and a 991.1 911, both with non-sport PASM. The GTS being an additional 10mm lower pretty much guarantees there will be times I am not happy.
Interesting. Guess the hydraulic pressure can bleed off the system and the nose would slowly drop. Not good if the nose is parked over a curb.
But to me there is the psychological aspect of listening to your 100k plus car crunch on pavement. Also I have crazy underground garage situation in which even when angling car you will scrape every time. So in addition you are driving around with chewed up front spoiler and have hassle of replacing at which time it will inevitably happen again. (Sorry for rant).
I went with FAL and have had my car for several weeks and I'm very pleased with it.
That is exactly where I am. I am so **** about my cars that I would likely have an aneurism if I heard and/or felt the car scraping. FAL does not guarantee that you'll never scrape, but it certainly lessens the chance. FAL with strategic entry to gas stations, parking lots, etc should make it a mostly non event - I hope!
I too had the same dilemma, but someone said that with FAL you have to remember to use it... If you're on the road and there's a bump you don't see at the last minute, then crunch... I decided to save the cost and risk it out
I am one of those who said that you could buy 5 spoilers, repaint for the cost of the FAL. I have a GT3 which is lower than the SPASM C2 by a bit, which I also have. The GT3 lip does not require painting, installs in 5 minutes and cost $179 plus shipping. I have FAL on the GT3 but not on the SPASM C2, My C2 has no major damage to the front lip (which must be painted on replacement ) but I can see the effects of scraping. It is impossible to avoid where I drive.
So, after all the bloviating, my opinion has changed. I consider FAL a must for any low car.
There are lots of opinions on FAL. I've read Posters say, and rightly so, that pay for a new lip 5x for the cost of FAL.
If any of your regular locations you visit require extreme care not to scrape then yes get it. Otherwise you will not remember the one time it matters and you will be even more upset cuz you had FAL and forgot to use it.
Good point. Porsche needs a forward looking radar device that automatically engages FAL when it senses a collision with a low object. Shouldn't be a penny over $10k....
