Replacing radio buttons
Old 05-07-2019, 10:57 PM
flickroll
flickroll's Avatar
Dare I ask the price of a new one?
Old 05-07-2019, 11:32 PM
Bob Z.
Bob Z.'s Avatar
Received 3,455 Likes on 2,359 Posts
$64.95 a pair on Suncoast (https://www.suncoastparts.com/product/PK992RK.html). The one on the right in my car wobbles as it appears it was not put on straight. I can get it replaced under warranty but I surely do not want to go the dealer for just that so I will wait for my first free oil change; however, if I can get them off I may do a little customizing.
Old 05-08-2019, 12:12 AM
APristi
APristi's Avatar
It is a PITA to remove and you might end up nicking something unintended. I suggest you go to a dealer and have them do it
Old 05-08-2019, 09:27 AM
Bob Z.
Bob Z.'s Avatar
Any hints for me? If I do not try a little more it is going to bug me for the next 6 months!
Old 05-08-2019, 10:00 AM
APristi
APristi's Avatar
Get ready with some tweezers to fish out the left over plastic. Pull nice and slow with a firm grip, not much help
but that’s what i did
Old 05-08-2019, 10:13 AM
Bob Z.
Bob Z.'s Avatar
Maybe I will wait. I found a pic online albeit I am not sure what PCM it came off; I wonder if ours come apart like this:
Old 05-08-2019, 03:54 PM
Cyberbug
Cyberbug's Avatar
I replaced one early on as the it was bent on delivery. Just the **** not the pcm part.
took the car in to dealer the tech was not able to pull it
but I did, you need to use both hands or fingers of both hands
put the index and middle finger of each hand behind the **** and pull hard
it pops straight out
i had already pulled it out once at home
you can use a plastic trim removal tool as well specially made for clips, use a microfiber next to console for leverage which ever works
Old 05-08-2019, 04:02 PM
Bob Z.
Bob Z.'s Avatar
Thanks, my left one is bent so it appears to wobble when turned. That may be making it harder to remove. As long as I know they can be pulled off without removing a screw I should be able to get them off. Did you recall if the back of your has a square hole like the one in the above picture? If so maybe the cover can be removed as well and I can separate the parts for a little customizing.
Old 05-08-2019, 04:07 PM
Cyberbug
Cyberbug's Avatar
I had the same issue left one was bent/ tilted. Seemed to be broken on the inside. Luckily no damage to pcm.
first I thought it was designed that way. I did post a thread on it (search) can’t remember how many pictures I had in it.
it was more like in post #13
Old 05-08-2019, 04:08 PM
Cyberbug
Cyberbug's Avatar
https://rennlist.com/forums/991/1127...-off-axis.html
Here
Old 05-08-2019, 04:15 PM
Bob Z.
Bob Z.'s Avatar
Actually, the pic in post #13 shows the front of the **** after the cover was removed, my bad.
Old 05-09-2019, 08:55 PM
Bob Z.
Bob Z.'s Avatar
My dealer is sending me replacement ***** in the mail and I will return mine and it will be processed as a warranty claim so it will not cost me anything. I do not want to remove them until the replacements arrive but I was able to take the cover and chrome ring off, which is what I wanted to do since I hate chrome - I will change that and be ready for when the new ones arrive.
Old 05-09-2019, 10:14 PM
Kelsey
Kelsey's Avatar
Sorry ... mistake
Old 07-18-2019, 03:45 PM
TimD
TimD's Avatar
Anyone have success removing these ***** without destroying them? I got a new set but still haven’t figured out how to remove the originals. Saw an EBay seller saying the way to do it was to remove the caps and remove a small screw. Any help would be greatly appreciated. Looks like my 15 Cayman has the same PCM as the 991s.
Old 07-18-2019, 04:33 PM
duxsi
duxsi's Avatar
If they're sticky, simply use some baby wipes with good old fashioned elbow grease.
You can also use a cloth or tissue with some rubbing alcohol.
The cheap coating comes off and they are as good as new.
Quick Reply: Replacing radio buttons
