X51 kit - 991.2S - Suncoast
#136
Congratulations. Sounds like it's a nice package: torque that you can feel, a bit of a change in sound track ( for the good), and marginally perceptible turbo lag. I can't imagine the PDK shifting quicker but then I'm rarely in sport plus.
How does the car drive when you're not pushing it? Driving through town, stop and go, normal traffic city driving? I would presume it's the same as before since the (bigger) turbos wouldn't be in play?
8 hours+/- for complete installation? I wish your service reps worked around here! Well done.
#138
Definitely has a lot of Grand Tourer character in a good way. The added low to mid range torque gives the car that big engine in small body feel.
The engine response is excellent, last Xmas I was thinking about a 488 Spyder and spent about 8 hours in the test vehicle. The engine in that car is fantastic, super responsive - hits the redline like a hammer. My S arrived in Feb and I felt the engine had a lot of that 488 character in terms of responsiveness. The X51 has magnified that even more.
Thats good to know! I'm very happy with the move and certainly very surprised at how much harder it pulls (obviously because there is more torque across the whole rev range
#142
I'm glad everything worked out for you!
But right now all your observations are subjective.
Unless you can supply objective test data before and after, it's all subjective.
My 991.2 C4S has more than enough power, I can't understand modifying a perfectly good vehicle for very little HP.
I would be veru concerned that the modified product would have performance and quality problems.
I'm glad you have none.-Richard
#143
Received 5,402 Likes
#144
I run my car in a series that involves hills and also is pure hill climb - torque wins out in this environment
#146
I was expecting the differences to be more subtle than they actually appear (I will log the car on the clock as this generates a lot of data across the performance range).
Another point worth noting is the transition to peak torque appears smoother than with the original S specification. I noticed this because I'm having to go through a run in period so cycle up and down the rev range.
My gut feel is this has been engineered in to further enhance the linear feel of the car. I am genuinely impressed.
#147
#149
#150
At the same time, all your comments are personal opinions based on ZERO facts. Do you have anything to back up your points the X51 has no performance benefit and installing one of these is plagued with performance and quality problems? Porsche must be doing a great job marketing the GTS on fairly tales.
Here is my factual contribution ......
This is the OEM X51 Powerkit that the GTS has. Look no further than the published performance numbers Porsche releases.
What performance and quality problems?? Unlike the .1 X51, the .2 X51 is pretty much software and larger turbochargers. Much less intrusive work than on the 991.1's. I'd have zero hesitation on this version. The .1 required dropping the engine and doing work on the top end.
As far as the mentioned shift point differences when in sport/sport + when pushing the car that is correct. The X51 software has different more aggressive software mapping. Like the jump from Sport to Sport + (although not that extreme).
Let me know when the next block party is.
