Oversized tires question
Hi guys,
I was wondering: If I put 325/30R21 on my Porsche Turbo 991, will it cause any issue with the AWD system as it's bigger than the original 305-30-20?
325/30R21 are the OEM on the GT3 RS, but it's a RWD, I just wanted to make sure.
Thanks!
Thanks!
There may be a couple of issues fitting them. They are .8" wider and 1.7" larger diameter. The rotational difference limit front to back for the AWD used to be 3%, honestly not sure what the 991 limit is but this a 6.6% difference. Hopefully someone can give you advice on whether that will not hurt the AWD. Beyond that I remember reading an interview with AP about the development of the RS and he said they could not fit the rear tires to the turbo shell. They had to develop a new narrower inner fender liner. Since there are no intercoolers in the RS they could do that.
Last edited by CDinSing; 07-06-2016 at 06:05 PM. Reason: Fixed the % difference to reflect actual F/R rev/mi
There was a recent post where someone had just done this tire change on the rear with no issues although they also changed the fronts to 245 I think...I did a quick look but couldn't find..sorry..poke around on the two forums
you have to kept the ratio f/r diameters about the same. I have been running 265/35/20 FR and 325/30/20 R MSC2 for over a year, on stock wheels, 32/36 psi for daily driving and they are absolutely fantastic.
This set up would also be an improvement for on-track grip as well?
I'm running 335/30/20 and 265/ 35/20's Rears are mounted on a 13" rims and fronts on 10.5". No issues and with the techart lowering springs, I still get back the ride comfort lost on the lower springs, because of the higher profile on the tires.
No wheel gap at all - but she scrapes in front if I'm not careful. Fatter / taller rears with lowering makes front sit lower. I have like 2" of spoiler clearance, but it looks cool as hell! Really no issues...
