Anyone here messing with ThinkDiag
I meant to come here and ask what TOP was … it was a few weeks back … but I never made it here to ask.
I did not have an electric power steering module listed in my module list… just power steering … I was using a launch x431.
Southpaw (09-24-2024)
Thanks.. I bought this Thinkdiag+ just for that feature so I might have to return it.
I changed so many things that I think it have gotten the value out of mine, regardless of the steering.
If you look at the spreadsheet screenshot I posted you here you can see the “value” I have gotten so far, nvm the SIA for oil and battery changes.
https://rennlist.com/forums/991/1384...l#post19523446
Made the backlight of my gauges stay on all the time, made the seat adjust back farther when I open the door, turned off the back up camera at 3mph, made 4bars in my oil reading, raised my boost gauge for impending tune, changed to true temps. Gonna try a PDK relearn with it tomorrow
If you are doing PDK relearn (and by that I mean calibration not adaptation reset) see my post here about the PDK Torque process being a predecessor activity before calibration: https://rennlist.com/forums/991/1384...l#post19664137
At least fix your lying coolant temp gauge before you return it. 😎
I am a little surprised on “no difference so far”. Did you do the recalibrate or relearn or both?
Did the calibrate take 12-15 minutes and thunk through the gears and change the idle rpm from 800 to 1200 to 1000, etc?
When I did mine (via Cobb Accessport) the most noticeable difference was the smoother 2-1 downshift … got rid of the thunk/clunk.
Got it. I did the relearn procedure first which wipes out learned adaptations followed by the recalibration. That was noticeable for the first 15 miles or so … just feel really weird. After that the 2-1 downshift was the real difference. It’s good to know that the calibration can be called by the ThinkDiag … thanks for confirming.
