What would cause this scrape on LF PCCB caliper of 2015 Turbo S. Changed tires yesterday and noticed this. Last tire change by Porsche dealer and no mention. Any comments?
Just superficial damage to the paint. The caliper itself should be fine.
This happened with the PCCBs in my 997 Turbo, and it happened with the PCCBs in my 991 Turbo S. The sound when a rock gets caught between the caliper and the wheel is nothing short of horrendous.
Yeah pretty common with these. Rocks get caught between caliper and wheel. I'd put some touchup paint on it for now. Can always repaint the caliper later on when you have time.
Stone/rock wedged in between caliper and barrel of wheel.
Most probably already know this...
.. if you hear a scraping from your wheels/brakes that might be a rock you picked between your caliper and wheel (or worse, scraping against your rotor), stop in a safe place, back up quickly and brake hard in reverse. Several times.... This will usually clear the offending rock and prevent further damage.
