Built4L
Originally Posted by Payam
I agree, it will be a pain in the *** but this car is already racecar and I rarely drive it on the street. I'll play a bit more with the WMI with Wayne to find the happy medium. I know he doesn't want to go bigger nozzles, so maybe adding two more before the IC would help. Another idea was to put water spray bar over the intercoolers and have the meth kit spray water over the intercoolers while doing runs. Everything is basically setup for it, just need to get the cooling bars from summit. Yes 850whp is exactly what I think the car was at for the 184mph runs. I'll post a video so you can see how I was rolling into second as fast as I could then punching it from there.
Whats up brother. Nothing wrong with trying a little more meth. Is your motor going to blow up if your add a lot more. meth? Of course not. Bad comparison, but at this same NFZ event on much warmer days in April in the heat of the afternoon I'm seeing start IATs up in the 130's. End of the 1/2 I'm in the 80's. Of course just a couple bolt-ons nothing like what you have but it gets my little 700hp car near 180mph traps. Your setup will create more heat than cars like mine and so I don't understand why the tuner doesnt like meth. It just artificially creates lower DA for you and adds a little fueling for stability. You are good at setting up a good reliable meth system and testing so why not at least try to add larger nozzles (maybe some dual CM14's) and crank up the pump pressure and do some tests. Can mix some meth and boost juice. I would bet your car runs a lot stronger with more meth/a lot lower IATs.
I think it will be better with 4 nozzles and adding two before the intercooler, so I will play with that.
It's just his preference and I would tend to agree with him. I already have port injection and I don't need methanol for supplemental fueling, so if I spray more it will start to mess with bank to bank fuel trims as flow distribution is not always equal. For your setup it's mostly used for supplemental fueling vs my setup only for cooling so it's a different ballpark. We did have larger nozzles (BM7) but we cranked it down to BM5s.
Much fuel in that. And could substantially cut down on IATs. It's pretty close to free to just try.
Not too bad, sorry I haven't updated you guys lol.
Ran the car at the last NFZ event a couple months ago. The car did 193mph on my kill map at 42psi.
At the end of the run we had some coolant leak, so we thought it was the head. I turned it down and did 188 on the lower map, no coolant leaks. Then turned it up again, and we got a leak.
So we're not sure if the head is slightly lifting or not.
I added a coolant pressure sensor and will be logging this week with Wayne to see how things are looking. Once we confirm everything is OK, the car is going back under the knife.
Changing the turbos to slightly larger turbos and will be trying out the Xonas since Garrett is on a never ending back order. Also, the main part of this will be the air to liquid change. No more methanol and will be fitted with an icetank as well.
Another main issue I had with the Garretts is that I really need to run them hard. To make 1100whp, they were spinning at 165k RPMS (max advised is 150k from Garrett) and run lots of boost.
I'd like to make 1100whp on less boost if possible with the new setup, which should have lower IAT as well and be more efficient with my goals.
Good to hear it's still going!
I've experienced the exact same problem on a diesel with respect to the coolant leak - at 40lbs, no problem, but anything above that, head was lifting and we determed we had stretched the bolts, fortunate that this was discovered before lunching the motor.
Cheers,
Cheers,
On the air-to-water setup, is this something you guys are fabricating or someone else? I know Wayne mentioned wanting to try one when I bumped into him at John's shop last year but other than Dave, I am not aware of anyone else using one on the 991 platform. Is this something that would replace the air-to-air or run in cofunction? Would a street car see benefit from this or only high horsepower cars looking for maximum benefit on the track/half mile? I know all the V10 guys go this route but I figured this was partly because there was nowhere to mount an air-to-air setup on those cars.
Excited to see you turn this up and maybe we can meetup again this fall/winter at NFZ!
Thank you for the update.
yes,…sounds like the head is lifting.
h11 tool steel head studs made by a1 technologies in Paramount solved that problem for me on a built NSX years ago,…
I don’t know if they’re still around,…???
It appears a1 technologies is out of business,…
has anyone dabbled with the inconel 625 head studs offered by protomotive?
they claim to hold 1000+ whp on the 997.1 engine…
they don’t list a power rating for the 9a1 engine.
It sounded really good on Instagram. That lope made me rethink keeping my stock heads lol.
It's going to be a custom fabbed by the same person who made my turbo kit etc. It replaces the air to air system and adds a few things etc. New chargepiping, all new intercooler system, dual heat exchangers, ice tank, waterpump, wiring and hoses to plumb everything.
Street cars can benefit from it too but it's very expensive to do. Yes, the V10 guys do it because of that exact reason you stated and kinda the same with us too. At this power level the intercooler sizing that we currently have is not enough, especially the "airflow" or lack of that gets to it.
So we need to evaluate things one at a time to make sure all is well.
We played with that on the dyno and wasn't too impressed.
At 32psi (1000whp) we added 3* of timing to see if that helped much and it was only 30whp. Not worth the risk for little reward. 1psi made 20-30whp, so we went that route.
However, I do think that 42psi is a lot. Next time on the dyno we will evaluate lower boost pressures to see where it maxes out.
