Intakes: awe vs eventuri 991.1
Hello folks,
as the title says, which intake would you prefer and why?
some threads state that eventuri might have flow issues with higher power. Not much on the AWE. I really want to pull the trigger here, but i am torn. Looks wise, eventuri 4 sure. But performance is also important.
what are your opinions?
Are there any reports that Eventuri actually has flow issues with their higher power? Maybe i'm buying in the hype, but i've owned a few Eventuri Intakes myself already, but, they actually do real flow testing, compared to some of the other companies it seems, so it seems a bit odd that out of all of them, theirs would be the one that doesn't flow well at higher power?
I love my Eventuri in terms of fit and finish but I have been told the stock box flows better from a cfm standpoint. I don’t notice any difference from stock but would be hard pressed to tell as I did a tune with upgraded coolers, y pipe and plenum at the same time.
The following 2 users liked this post by onfireTTS:
4flynlow (08-04-2020),
Redlinerobert (08-03-2020)
AWE makes great products. Eventuri is top notch as well, one of the best intakes you can purchase for performance and looks.
We have one of the AWE products in stock if interested and can get you Eventuri as well.
Feel free to contact me for pricing!
-Josh
-Josh
Your #1 Dealer for Aftermarket Performance Products
BC Forged / Soul Performance / Akrapovic / Bilstein / HRE / AL13 / CSF + more
Orange County, CA
Email: info@merakiautoworks.com
Text/Call: 213 394 2886
Website: www.MerakiAutoworks.com
Orange County, CA
Yes. BMC. The only thing they will do is flow more air at less pressure drop if you exceed the factory filter. Pure Stock, the factory filter is fine.
I've heard the same issues with the high powered cars on the Eventuri for some reason.
The stock air box is hard to beat, Porsche made sure these turbos got good airflow. BMC drop in would probably be the easiest route.
On my car I retain the rear stock air box using as a heat shield and air duct. I used x2 huge 3.5" oiled filters and our intake plumbing to the stock intakes.
I'm using one of those filters on my 800whp 335i, so I know it flows plenty
-Payam
-Payam
So i did go with AWE. Installed it today. Obviuosly carbon is pretty,
fitment however is not. Grooves for the air lines on top of the filter are poorly made, none of the lines clip in. Had to make modification for the lines to actually stay put. Also alignment with with stock connections is also not impressive, top side of the filter that connects to the stock fresh air inlet is not sealing well, filter housin is of by 1/3 inch which could prevent the air pickup from outside vs engine bay.
when it comes to price and quality, i would give this a 5/10. At that price point i expect nothing but perfection. I prolly shoulda went with eventuri
-Josh
Eventuri is a work of art. My only question is their statement "The two individual filters provide a larger filtration area as compared to the single stock panel filter".
I'm skeptical that two small cone filters have more square inches of surface area than the large, single panel filter. I'll measure my spare panel filter and post back. What is the in2 of the Eventuri filters ?
If you were to believe the marketing for the system, the filter sizing and inverted shape contributes to the technology for higher velocity of airflow. Who knows without aN independent scientific comparison. I definately notice an improvement in sound. You can hear the air coming through.
https://www.eventuri.net/filters/
