2014 991 turbo pdk .. transmission oil & clutch oil
Hello everyone,
i have to change 991 pdk transmission oil & clutch oil, I am having a hard time in locating the drain & fill plugs for them...
I believe while standing in front of car, left side is for transmission oil, surely the transmission oil drain plug is at the bottom of black colour sump & fill plug is at left side of housing & no idea for clutch drain plug..I have heard clutch fluid is supposed to be filled separately then transmission fluid....? Both of them should not be same oil & same plugs.... I am confused.
Thankyou for having a look at this thread ...
rahulsingh (04-15-2020)
This should help.
https://rennlist.com/forums/991/1135...l#post15726895
There are more posts if you run a search.
mikerosi is right, but if your car is modified and you track it hard, I would change it much more often. My car has 12k miles and I have changed it twice already.
Such as coincidence. I am also looking into doing this soon. I've found that between the clutch, PDK, AWD controller, and final drive there are 4 fill plugs and 5 drain holes. There are two types of fluids need :
Below and attached are some threads, videos, and documents that will help.
Post #1 and #16 are important here:
https://www.planet-9.com/threads/diy...l-mode.237865/
https://mhhauto.com/Thread-Porsche-PDK-fluid-change
- 4Liters of Mobilube PTX 75W90 (I've only been able to find it in single liters from Suncoast)
- 6Liters of Pentosin FFL-3.
The following 2 users liked this post by aft86:
GTR_ Ed (06-12-2020),
rahulsingh (04-16-2020)
hey. Just saw your post. You have the clutch fluid fill correct (behind the pipe). You do not have the right trans fill. It’s on the other side.
rahulsingh (01-25-2022)
No it states that if a car sits for 5 years or more, the fluid must be changed. Says nothing about changing fluid every 5 years for a car that's driven.
