TPMS Sensors not learning
Old Oct 22, 2023 | 09:57 AM
2fcknfst's Avatar
2fcknfst
Mine have lasted five years, five months, going to the tyre shop tomorrow to replace them ... Very irritating.
Am tempted to change the ones on the OEM rims too as they are currently off the car.
Old Oct 30, 2023 | 10:58 AM
Dennis C's Avatar
Dennis C
Rocky Mountain High
I think the batteries generally last for about seven years or so. This was the case in my 997. Are they different in the 991 cars? Come to think of it… my car is nine years old and I’ve never had an issue with a TPMS sensor battery.
Old Oct 30, 2023 | 02:40 PM
Wayne Smith's Avatar
Wayne Smith
Porsche changed TPMS technology in 2009. The sensors in my 2010 C4S are still the originals with 153K miles on the odometer.
And while I'm typing, by way of introduction, a good friend just bought a 2015 TTS from another Forum member here, upgrading from a beautiful 997 GTS. Since we share maintenance tasks amongst our cars, I've been lurking to learn anything that might help in that regard.
I've been very impressed with the group input here. Thanks for what I've already learned and will learn in the future from all of you.
File Type: jpg
Old Nov 1, 2023 | 04:15 PM
Foosh's Avatar
Foosh
Originally Posted by lowpue
ok...i just had this problem.....they worked with my summer wheels but wouldn't learn winter wheels. Then when i put the original summer wheels on...it sis not learn them either.
here is the trick....go onto your tpms settings and select winter or summer check box. If it's on summer, then select winter or if it winter select summer. The key is change the setting....and boom! Learned immediately!
This "trick" is the Porsche SOP every time you swap to a different set of wheels/tires/sensors. The TPMS menu for your model is loaded with all the approved OEM sizes and tire type, so when you go to the TPMS menu, check the box with the size and type you just mounted, then drive the car, and mine have always auto-learned in as little as 1-2 miles.
There is a section in the owner's manual specifying that.
Old Nov 1, 2023 | 04:21 PM
2fcknfst's Avatar
2fcknfst
Mine just took a couple of days to marry, all good now.
Old Nov 1, 2023 | 04:25 PM
Foosh's Avatar
Foosh
I also seem to recall that after swapping, the car needs to sit for maybe an hour completely shut-down before starting the drive and re-learn process. So if it doesn't work the first time, try that.
Old Nov 6, 2023 | 01:54 PM
ottodawg's Avatar
ottodawg
Also keep in mind, the 991.1 and the 991.2 use different sensors. When I purchased my HRE Wheels/tires they installed 991.2 TPMS sensors in them. You can drive forever and they'll never register. Once swapped they registered in about a mile. Always use the summer/winter/summer trick to force it into "Learning" mode.
Old Nov 6, 2023 | 01:56 PM
2fcknfst's Avatar
2fcknfst
Yessir, when Tyre Guy was trying to program them, he had two different frequencies to choose from and 20 different models...
