911 Turbo S door decal
I’ve noticed some came from the factory this way (I assume).
I can get a set for $29.
https://renndecals.com/collections/d...-s-door-decals
I cant decide, and my car already has a clear bra on the doors, so I’d be applying this decal over the clear bra, not sure if that’s an issue.
Thoughts?
Thanks.
Thoughts?
Thanks.
I ordered mine from Suncoast because the paper it comes on fits perfectly to the bottom and front of the door. So placement, IMO, is perfect. Don't know about the Renndecals. Also I have washed mine several times and applied Can Coat quartz over them with no issues.
I ordered my Turbo with the decal installed from the factory and I’m happy with the decal. It is the exact same decal as you can order from your local Porsche Parts department or Suncoast etc.
My PPF was installed directly over it and you can feel the film at the borders of the decal. If you put the decal on top of the PPF, obviously it comes off with the film if you ever take it off. Not a big deal though
I’m hoping it comes the same way, if not I’ll have to guess.
