DSC Module for 991.1 Turbo
Hey Guys, Im looking in to get this module for my 991.1 Turbo that i track, as an alternative to lowering springs, I know they aren't the same but just an add on that would help on the Track. Has anyone tried this on a turbo? is it worth getting? some have suggested that the Turbo setup is already soft and agile and won't benefit much from this. Can anyone give me some input on this before i make the investment. Thanks
I am going to the Audi Club open track event in April at VIR, and DSC is going to be there and is offering to let me try it out on my 991.2, along with Randy Pobst helping out with getting it dialed in for my car if needed. (That alone should be worth it - that guy is hysterical!) I have lowered my car, but am hopeful that this device can help with turn 5a and the esses! We'll see, but I'm also interested in hearing more from those that have it on their turbo.
I added DSC V2 to my 991.1 TT that does not have PDCC. I feel it offers the benefits of PDCC without an expensive PDCC retrofit (if it's even possible). You definitely feel the difference as there is less body roll. Also, the range is broader, so the car rides better on rough surfaces and seems to stick better to bumpy roads. I would definitely recommend it. As you can see from the installation videos, it takes all of 15 min. to install it, and you can easily swap back in the OEM unit when you sell the car. I should add that I've not yet tracked the car with the DSC in it, but expect some material improvement based on back roads driving.
Hi Randy,
Do you have the front axle lift and a sunroof on your 991.2? The DSC still has issues with those.
John
John
Received 1,682 Likes
It's just that TCP Racing's developmental 991.2 had neither a sunroof nor the front axle lift system. Porsche changed something on the 991.2 that now causes fault messages to be displayed when you have a DSC Sport installed. The sunroof fault goes away as soon as you close the sunroof but the FAL fault freezes the FAL system after about 20 seconds until you turn off and on the car to reset it. TCP Racing will be able to come out with a fix as soon as they are able to get someone with both systems to go into their facility to be hooked up to their computers. If anyone has a 991.2 with the front axle lift system AND a sunroof and would be willing to bring their car over to TCP Racing in Jessup, MD (20794), I will offer them a free DSC Sport V2 module for their trouble. I have no affiliation with them. I just want my DSC module to work without causing any faults in my car.
My initial reaction to the sunroof and FAL issue was also surprise, but as I thought about it, it makes sense. There is definitely a sensor feed from the sunroof to the vehicle dynamics computer because when the sunroof is open, the rear spoiler deploys higher. I'm guessing it may also affect the handling map. If there is no sunroof and no feed, I can see how the DSC might be confused. You also would not want the system to be active when the front axle is lifted, so I can see how that might affect the DSC, too. There are probably a few lines of code that need to be changed so as to eliminate these bugs.
I'm not sure what the other poster is asking about when he says "descriptive idea of how the car changes", but the DSC is described on the DSC website. http://www.dscsport.com/porsche/#991
I think it's worth the money, but that's really something specific to the buyer. For what it does (aid turn-in, reduce body roll, and at the same time improve ride quality), and the cost and ease of installation, I'd say it's worth it.
FAL didn't surprise me. And now that you remind me ...
the vehicle dynamics computer ... the sunroof is open, the rear spoiler deploys higher.
Received 1,265 Likes
In my 991.1 GT3, DSC conflicts with front axle lift (obviously no sunroof there) - when I try to change suspension mode with front axle lift on, the button light goes out of sync with the display (e.g., the button may show sport suspension and display non-sport and vice-versa).
Going back to the question on what effect DSC has - off the track, the most noticeable things are twofold:
1. Dive on braking and squat/porpoising on acceleration are reduced, and the car feels more stable and confidence-inspiring
2. When driving straight, big pumps are unsettling the car less.
On track, you get all that plus that inside wheels are not unsettled by curbs as much, so you can take curbs more aggressively.
There are only the very obvious things, I'm sure it has some more subtle effects as well.
It's a worthwhile mod.
Edit: Also, jut remembered I have a spare 991.1 module (bought multiple not realizing that 991.1 and 991.2 are different). If anyone wants it, I can sell it cheaper than OEM (let's say $950 vs. $1300 from DSC). It's brand new, effectively unused - I only installed it to check if works to make sure I will not be selling a brick. If anyone wants it, let me know.
Edit 2: It is sold.
Edit 2: It is sold.
2. When driving straight, big bumps are unsettling the car less.
I talked to TPC Racing about the DSC V2 for the 991.2 TTS, and they confirmed that it has some issues with the front axle lift and the sunroof. I have neither, and am scheduling a time to take it up to them to get a full track alignment and look at more suspension options and tuning. I will report back.
