turbo under boost issue??? 911 turbo 991.2
won't boost above 13 psi on boost gauge.Also overboost (orange bar) appears 10/13 psi. this happens in all modes manuel or auto…thank you!!!
Basic Sponsor
Hi radar. Feel free to reach out and I can try to help you trouble shoot. Could be a few things
Proud TOP Porsche Distributor For:
Kline-Innovation - ams Performance - TiALSPORT/XONA - #1 COBB PRO TUNER - CSF - IPD Plenums - DO88 - dodsonmotorsport
310-600-1850 - sam@bydesignauto.com
Radar, Your outside ambient temp is 29F (was snowing)? The ECU is measuring air mass, cold air , cold humid dense air will allow the engine to make the rated power output with less boost pressure. The boost pressure reading is not a constant. The engine will always produce the power output with timing and then govern/drop boost when the power output is met.
thank you ,issue has been occurring since august so doesn't seem weather related. car is at dealer for second time.hopefull they will sort it!!!
