991 GT3, GT3RS, GT2RS and 911R 2012-2019
New Cup 2's. Dealer set pressure to 36/41?
Old 02-10-2017, 12:37 PM
FastLaneTurbo
FastLaneTurbo's Avatar
I use the Door Sticker to set cold Tire Pressures on Cup 2's, F29 psi, R33 psi. Normal Road driving will increase pressures 3-5 PSI. depending on how aggressively you are driving. Track Driving will increase pressures 5-7 PSI. My targets for hot pressures on track are F 32 psi and R 33 psi which seem to work best. Pressures will also vary with interior and exterior ambient temperates. Also the pressures on the Tires exposed to the sunlight will heat up and pressures will increase, often by several PSI.
Old 02-10-2017, 12:39 PM
robmypro
robmypro's Avatar
Received 1,784 Likes on 1,027 Posts
Okay thanks!
Old 02-10-2017, 12:40 PM
mcsmcs1
mcsmcs1's Avatar
Originally Posted by Archimedes
It's the law in California. Dealers have to set tires to max pressures when they service a car. I always bring my gauge and drop them before I leave the lot, so I don't lose a filling.
The California Air Resources Board’s (ARB’s) Tire Pressure Regulation took effect in 2010, and requires automotive service providers to check and inflate each vehicle’s tires to the recommended tire pressure rating, with air or nitrogen, as appropriate, at the time of performing any automotive maintenance or repair service.
The purpose of this regulation is to reduce greenhouse gas emissions from vehicles operating with under inflated tires by inflating them to the recommended tire pressure rating.
Old 02-10-2017, 12:41 PM
Archimedes
Archimedes's Avatar
Received 3,869 Likes on 1,902 Posts
Originally Posted by fbroen
Max pressure, or recommended pressure on door post sticker? Max would seem to be nuts?
Max pressure from the manual, 36/44. Though when I picked my car up from service last week, the pressures were 39/46. And I forgot to check and didn't have my gauge. Was an awful ride home.
Old 02-10-2017, 12:42 PM
Archimedes
Archimedes's Avatar
Yup, and they interpret the recommended tire pressure rating as the fully loaded car pressures in the manual, i.e., the upper limit. I've asked them to drop them, but they won't do it.
Oddly, whenever I buy new tires or have my snows swapped at America's Tire, they'll do whatever pressures I ask them to.
Old 02-10-2017, 03:23 PM
bronson7
bronson7's Avatar
I'd be curious to see what they do here in Canada. I'll have to find out.
Old 02-25-2017, 10:30 AM
robmypro
robmypro's Avatar
Hey guys, when you mention 29/32 cold, or 30/32 cold, is this based on the in-car data shown? The reason I ask is that I have a digital gauge and find a wide variance between what the car shows vs the gauge. I set the front to 29 with the gauge, but the in-car system shows 26 cold. Similar variance in the rear.
Old 02-25-2017, 11:28 AM
bronson7
bronson7's Avatar
I also find a slight variance but not enough to be concerned.
Old 02-25-2017, 11:32 AM
mwar99
mwar99's Avatar
Mine is usually spot on.
Old 02-25-2017, 11:37 AM
robmypro
robmypro's Avatar
Yeah, this is like 3 psi difference in the front. I drove it the past week and had a spirited GT3 therapy session, but the rear felt too soft. I will use the in-car to set the tire pressure, jacking it up a few PSI and see how it feels. Thanks guys.
Old 02-25-2017, 07:42 PM
Sloopy
Sloopy's Avatar
I had mine changed in CA and dealer set to recommended pressure; 29 33.
Old 02-26-2017, 10:16 AM
BryanCO
BryanCO's Avatar
Check the calibration of your gauge and replace it if it's off.
Old 02-26-2017, 11:35 AM
robmypro
robmypro's Avatar
Hey Bryan. You mean the in-car gauge, right?
Old 02-26-2017, 05:32 PM
MileHigh911
MileHigh911's Avatar
No. The hand held Rob. They are not necessarily calibrated. I have one gauge that matches in car, and another off 2 psi every time
Old 02-26-2017, 06:37 PM
robmypro
robmypro's Avatar
Okay thanks! Will do.
Quick Reply: New Cup 2's. Dealer set pressure to 36/41?
