991 GT3, GT3RS, GT2RS and 911R 2012-2019
View Poll Results: Have you had engine misfire issues?
No Issues - Prior to engine F 03048
39
41.94%
8
8.60%
No Issues - Between engine F 03048 and G 05372
24
25.81%
9
9.68%
No Issues - After engine G 05372
12
12.90%
4
4.30%
Multiple Choice Poll. Voters: 93. You may not vote on this poll
Engine Misfire Issues
Old 02-11-2017, 11:33 AM
  #31
robmypro
robmypro's Avatar
Received 1,784 Likes on 1,027 Posts
Originally Posted by GT3 KSA
Also how often is oil being changed? I change mine every 5,000 KM and i use Motul 5w40
Yep, good point.
Old 02-11-2017, 02:41 PM
  #32
Cay_PI
Cay_PI's Avatar
Originally Posted by Princealidds
2015 GT3. F engine. 14k miles
Misfire issues, top end rebuild at 12k miles
3 track days
Do you know the engine number or the build date?
Old 02-11-2017, 02:43 PM
  #33
Cay_PI
Cay_PI's Avatar
Originally Posted by robmypro
Also, the early data we are collecting here shows that the top end change made after engine F 03048 did not in fact fix the issue. The DLC cam fix might have promise, but we need more data, and time. The first fix came in early 2015, the next in mid 2016.
Do we have one with issues on an F engine later than F03047?
Old 02-11-2017, 03:12 PM
  #34
robmypro
robmypro's Avatar
Poll shows 3 so far. Would be nice to know details about those 3.
Old 02-11-2017, 04:04 PM
  #35
Princealidds
Princealidds's Avatar
How do you the engine numbers? I know it's F
Old 02-11-2017, 04:07 PM
  #36
GT3 KSA
GT3 KSA's Avatar
Open the engine lid it will be on the top right hand corner when you pop it open
You can also open the frunk and see it on the passenger's side of the frunk cover if that makes sense
Old 02-11-2017, 05:36 PM
  #37
Waxer
Waxer's Avatar
Not sure I follow you, Waxer. This poll breaks it down even further than that, addressing mid-model engine revisions.
What am I missing here?
Between F 3048# and G #5372 . How do we know if its an F or G with a general response since there are some differences between the last F and first G (i.e. rev limiter and valve springs)?
Black gold (12-09-2021)
Old 02-11-2017, 05:50 PM
  #38
Waxer
Waxer's Avatar
The DLC is just a bandaide. The main factors I think that ameloriated/ resolved the issue of upper valve train failures were (a) revised oiling with the F and G (b) revised rev limit with the G and revised valve springs with the F replacement and G engines.
The failing valve trains exhibited wear on specific lobes. Wear is from excessive pressure and lack of lubercation on specific lobes. Not lack of DLC.
Even without DLC a valve train should last 100K miles.
Increased oiling, reduced revs ergo less pressure and heat and revised springs for reduced pressure equals less or minimized wear.
Old 02-11-2017, 06:27 PM
  #39
robmypro
robmypro's Avatar
Waxer, can you point me to data showing these changes? I am not aware that the GT3's RPM rev limit dropped from 9K between those revisions.
Old 02-11-2017, 08:20 PM
  #40
bronson7
bronson7's Avatar
Rob, I believe Waxer is talking about G engines in the GT3 and G engines with a reduced rpm in the GT3RS's.
Old 02-11-2017, 08:41 PM
  #41
robmypro
robmypro's Avatar
Yeah, I had a feeling. I am really trying to focus on the GT3 since all of the failures (I think) are attributed to them. I should clarify this in the original post.
Old 02-11-2017, 10:03 PM
  #42
R.Deacon
R.Deacon's Avatar
no issues engine : prior F 03038
total miles : 18k +
track miles : lots, after 2k break in
Mods: sharky
Old 02-11-2017, 10:06 PM
  #43
robmypro
robmypro's Avatar
total miles : 18k +
track miles : lots (sub 2:20 sebring )
Mods: sharky
Thanks. Can you tell us what oil you are running?
Old 02-11-2017, 10:12 PM
  #44
R.Deacon
R.Deacon's Avatar
^ oem oil/filter mobil one 0-40 changed 5 times now, always dealer oil service, 4 clean analysis thus far
Old 02-11-2017, 10:25 PM
  #45
Just in time
Just in time's Avatar
At the outset of there cars there were lots of threads regarding break in. One group argued for going by the book, another arguing that such was an old wives tale and that the car should be flogged right out of the dealers lot. AP clearly stated in RRV that break in is essential. I wonder if there is a correlation between break in and longevity/failure.
Quick Reply: Engine Misfire Issues
