991 GT3, GT3RS, GT2RS and 911R 2012-2019
911R's rear diffuser
Old 10-27-2016, 09:39 PM
  #91
PhilT3 (PT3)
PhilT3 (PT3)'s Avatar
Gentlemen.....I won't have this blasphemous talk!!! I just won't have it!!
Porsche is PERFECT....and every feature they put in the GT cars makes them faster and race ready!!! Don't even think about questioning this Fact!!!!!
Old 11-01-2016, 06:52 AM
  #92
Footsoldier
Footsoldier's Avatar
One things for sure - the diffuser is very low!
I know of many (most?) that have been damaged coming off the transporter. Both mine and other one delivered at same time are waiting for replacements under warranty.
I caught it last night on a relatively small speed bump, so glad it being replaced. (I'm hoping to keep the old one to use and have the new one on standby). I didn't put a front lift on my car, but the rear would be more limiting anyway, IMO. Just needs some care, but obviously worth it, for the ground effects...
Old 11-01-2016, 06:18 PM
  #93
bronson7
bronson7's Avatar
Maybe Porsche should add a rear lift option b/c of the rear diffuser.
Old 11-01-2016, 07:02 PM
  #94
Robert Linton
Robert Linton's Avatar
Am making a carbon fiber version with replaceable fins in different sizes.
Old 11-01-2016, 10:18 PM
  #95
MaxLTV
MaxLTV's Avatar
Received 1,241 Likes on 609 Posts
Originally Posted by Footsoldier
Thanks for posting, but from that list, for performance I'd take the R, because it will be generating a lot less drag. There aren't many 186mph corners in the world, for a road car. (Obviously the d/f will help under braking at the end of the straight)
So, pretty much the 90-100mph that's most relevant for faster corners of a race track I'd say. If RS at 94 mph is 193lb/88kg, then it's not doing much at all
We can assume the R is generating none in terms of feel, GT3 negligible. RS - my guess is it generates massive psychological levels of downforce....
On a non de-restricted road, downforce is not going to be a factor at all. On an autobahn at 180mph plus where it probably helps if there's a bend. Most likely the real reason for a big wing! (+ the racer 'look')
Sorry, but that's pretty ignorant.
First, unless you are driving completely in a straight line, R's aero set up will disadvantage it in terms of performance. Drag has much smaller role than downforce on cars with this low levels of downforce and high-power engines.
Second, 193lbs of downforce at 93MPH is not "not doing much at all". It's a freaking 4-7% more traction in fast corners, which in turn results in 3% higher speed through such corners, but also about 3% higher exit speed from such corners, and thus all the way through the following straight (tapering down on longer straights due to increased drag). It also helps with braking, shortening braking distances from high speeds by up to 6%, and thus enabling going at top speeds longer.
And if those numbers seem like not much, just consider that 3% faster is almost 2 seconds per minute or difference between Cayman GT4 and Corvette Z06 or Lambo Huracan. 2 seconds per minute is enough to thoroughly intimidate someone on track.
And this does not take into account other positive effects of downforce, such as reducing the impact of elevation changes on available traction, which adds confidence.
So if performance is the goal, even seemingly small numbers of downforce matter. It does not have to be something comparable to the weight of the car to matter.
Old 11-02-2016, 04:08 AM
  #96
Footsoldier
If you want to get really technical, the stripes on the R make it go 7.36% faster everywhere (unless it's dark), so it's quicker anyway. They also add confidence and don't add much to the weight of the car.
Depending on the thickness of the vinyl, they do add drag to be fair, but that's counteracted by the reduction created by the Porsche badge being a sticker rather than metal. (Not a lot of people realise that a metal badge would disrupt the airflow over the car, away from the roof indentations, almost negating the speed gain created by the go-faster stripes). Attention to detail - that's what Porsche is all about.
PS Since my diffuser has a slight dent in it, it's virtually impossible to drive in a straight line, due to the resultant lack of downforce.
Old 11-02-2016, 08:56 AM
  #97
CAlexio
CAlexio's Avatar
Received 1,975 Likes on 918 Posts
Bazinga!!!!!!
Old 11-02-2016, 12:55 PM
  #98
bronson7
bronson7's Avatar
Now, did I just learn something?
Old 12-27-2016, 02:40 PM
  #99
rs10
rs10's Avatar
Is that a good idea? While no one has specifically said this, I'm guessing the R's plastic fins are flexible. Carbon fiber, unless I'm badly mistaken, is not. Indeed, while I know there are different kinds of carbon fiber, did anyone every come up with a carbon fiber that could work as well as a bumper as the regular mumper material? For these fins, I think you'd want something at least as flexible and impact resistant.
And the undertray would be carbon too? Again, unless I'm badly mistaken, the undertray's purposes include protecting the engine (in addition to smoothing the airflow under the car), and from time to time can itself take a hit from speedbumps, etc. Probably carbon fiber is more suited to this use than to being used for the fins, but is it really the best choice? I'd prefer metal.
So while it's great that you are making an aftermarket version, seems to me it would be even greater if you considered some other materials. And if you make something like this for 996s and 997s, please let me know!
Old 12-27-2016, 03:18 PM
  #100
JasonAndreas
Technical Guru
JasonAndreas's Avatar
The fiber selection is not so much the problem as is the choice of compatible resin. For a rear diffuser that would need to withstand debris impact (but does it really?), something like Bayer Bayflex works really well (used on snowplow blades) and you could probably spec a cheap milled fiber. However the weight benefits would probably be lost.
Old 12-28-2016, 01:42 PM
  #101
rs10
rs10's Avatar
Wow, I can see why your signature says technical guru! So there are snow plow blades made of carbon fiber???
Slightly less off topic, am I correct that it makes no sense to think one can reduce weight with carbon fiber bumpers (unless one doesn't mind regularly replacing them when they get damaged)?
Thanks!
Old 12-28-2016, 07:40 PM
  #102
JasonAndreas
Technical Guru
The bottom (wear) section of the blades on commercial snow plows are a glass filled elastomer. Bayflex was used for this the last time I was involved with any type of casting. In that application there is no benefit to using carbon fiber. In a passenger car you might want the diffuser to be the sacrificial object instead of the floor pan? I would trust the automotive, mechanical and material science engineers that Robert Linton (unlike 99.95% of the automotive aftermarket) employs to have worked out the details. If you are balancing longevity with cost than metal might be the more appropriate material (aka Porsche knows best?)
Old 12-29-2016, 06:43 PM
  #103
Robert Linton
In reality, the tray might be made from a high temperature composite (BMI), the fins might be made of a less stiff carbon fiber, might have a bit of kevlar mixed in for tear resistance and/or even might have a bit of glass fiber incorporated to deal with some of the problems noted above. In any case, please forgive my shorthand for saying carbon fiber as a generic.
Old 12-29-2016, 09:35 PM
  #104
rs10
rs10's Avatar
OK, it starts to sound like a better idea. If you make something like this for 996s, let me (and everyone else on the 996 forum) know!
Old 12-29-2016, 09:39 PM
  #105
rs10
rs10's Avatar
Though based on some other posts above, it sounds like it might make sense to consider the fins a disposable item, as front lip spoilers sometimes are. In that case, a more disposable material might be the best choice. I don't know what Porsche used for their cup spoilers, but as they apparently sold for as little as $100, it was probably a good choice.
Quick Reply: 911R's rear diffuser
