RS: Rubbing front and rear
#46
After Sebring on Sunday, I am thinking that if I don't find big grip with new MPSC2 (I was on very old Dunlops) I may go back to less front camber, more toe in and raise tha car back up to where Porsche put it after factory drop off. (Just 2 turns up front and one turn up rear).
It felt I couldn't stop the car, not super stable and huge understeer on the way out of the corners.
Trying to make an appointment to get my car measured.
#47
Curious
On this big adjustments for a car that see track time bulletin, if I bring the car to the dealer I bought it from, who pays for the work and any idea how much it costs?
#48
I'm trying to sort that out with my dealer as well.
Seems like I have plenty of front camber for Dunlops..
I was wondering where all the understeer came from and why it wouldn't stop...
I only ran the tires 29-33 hot on track and street.
#49
I finally got my car to a Porsche Workshop:
They got an advice from Porsche for a specific setup for every 991 GT3RS to avoid to much scratching of the fenders. It is 2mm higher in the front and 5mm higher in the rear than my current setup (factory setup).
The car is currently at the shop and I will use it next week so I don't know much more.
Soon it will be a perfect off-roader...
Thoughts?
#50
Did the car feel unsupported on the front end? I ask because the tire pressures at 29 sound very low for a DOT tire and at that low I could see the front tires compressing too much causing a lack of grip in the brake zones. 32 is even a little low for a DOT tire but should be better. In my RS I always shoot for 35 hot front and rear. Anything over 35 and the car squirms for grip. Anything under it feels like the car is supported and lacks control.
#51
I just replaced my rears at 5000km (due to cording) of which about 1500km track and drove the fronts for another 1000km and 500km on track, at which point they felt like wood and the car was understeering everywhere. In the end it's still a 911.
The rubbing does seem to have stopped at this mileage, as Porsche suggests. Running the rears full stiff seems to have addressed the cording as well.
#52
Dealer is doing the bulletin work for the rubbing. Question for Trackcar and others: What is the conversion of 1.5 mm toe in for the rears to degrees? My service advisor wants to get the rear toe correct.
#55
This is a conversion chart for millimeters to degrees. Looks like 1.5 mm converts to only 10', so 1/6 degree. Does that sound right? I have double that on my GT3 rear.
#58
I am not getting detailed info...long story.
But I believe new front fender liners have been received.
I am pressing for the cause of the problem. If it is a bad alignment, fix it.
Any other thoughts?
#60
MHO is that the RS might rub on original setup when driven hard, not otherwise.
