991 GT3, GT3RS, GT2RS and 911R 2012-2019
Setup numbers RS
Old 07-04-2016, 06:42 PM
  #121
Kobalt
Kobalt's Avatar
Thanks a lot for sharing!
Old 07-04-2016, 07:22 PM
  #122
TRAKCAR
TRAKCAR's Avatar
Received 1,636 Likes on 759 Posts
Thanks for continuing write ups and feed back.
Still waiting for my appointment.
I'm not much use for input but trying.
Your tires are wearing really well. The front pad wear reduction is a surprise..
I can see pressures at 31/32 - 32/34 being ideal for most tracks and conditions.
Camber -2.7 seems plenty. I think -3 is too much for the front and my tear Dunlops wear perfect with -2.7. I will try 2.5 all around with MPSC2. I figure now they last longer but heat cycle out.
I got rid of the Dunlops so I can try next setup with fresh MPSC2.
Old 07-18-2016, 11:32 AM
  #123
TRAKCAR
TRAKCAR's Avatar
First annual service. Plus PDK oil and spark plug change. Also requesting info regarding mystery 13 page track setup modifications recommended by Porsche.
We'll see what what done in Germany and what not.
Fender liners for sure and raised the car for sure.
Old 07-18-2016, 11:45 AM
  #124
Kobalt
Kobalt's Avatar
Got this from Porsche workshop:
"But If the tire continues to grind in the rear wheel housing,
we can install Bump Stops according to a recent technical information, approved by Porsche in the rear shock absorbers."
Old 07-18-2016, 11:59 AM
  #125
signes
signes's Avatar
TRAKCAR and others, attaching a slightly updated version of the doc posted earlier. This was updated by Porsche July 5th, although I don't see much difference to the original, maybe just the spacers for the rear springs?
When my car gets back to the States, I am going to get a baseline alignment done and see if I can track down the magic 13-page Porsche doc.
Old 07-18-2016, 12:54 PM
  #126
TRAKCAR
TRAKCAR's Avatar
^^ Thanks guys.
Champion Porsche, both dealership and Motorsports department have had no information about this yet. Will find out what has and hasn't been done to my car and report.
Old 07-18-2016, 01:02 PM
  #127
Sarum87
Sarum87's Avatar
here is my set up data and thoughts
car was corner balanced
1/16" total front toe OUT
3/16" total rear toe IN
-2.7 front camber
-2.2 rear camber
running in open passing, advanced group
for those in bay area I'm running 2:00 at T Hill over the top configuration. this was 2nd day in the car and I dropped 5 seconds of my personal best in my previous gt3 991 so I was happy with the progress and this set up. no rubbing anywhere. I have not changed ride height. goal is to get to 1:58.
Old 07-18-2016, 01:06 PM
  #128
Sarum87
Sarum87's Avatar
almost forgot. I was at Thunderhill the other day and it was hot- 95- 100 degrees. I was running MPSC that had one track day on them. I was running front hot pressure at 31, rear hot was 33 and I was happy with this set up. So far tires look even wear but I've only had two track days on car- keeping an eye on wear.
Old 07-18-2016, 01:07 PM
  #129
TRAKCAR
TRAKCAR's Avatar
^^ See if you can get correct measured ride heights if at all possible.
My car has been unstable with front toe out, but that could be because of the bumpy track and -3F camber.
I agree with your camber settings -3F and -2.7R was too much.
Old 08-02-2016, 10:15 PM
  #130
Joe731
Joe731's Avatar
Default rubbing issue
Well,
I was at the Glen this past weekend with the RS and noticed that my left rear tire was cording again on the outside. This happened the the first left rear tire after 40 heat cycles and happened to this one at about the same point.
I was a bit surprised as a now have 2.7 degrees of camber in the rear whereas on the first set I only have 1.7 degrees of camber.
I looked carefully at the wheel housing and think that it is rubbing, though in truth, I never heard anything that sounded like rubbing, so I don't think it's a particularly hard rubbing.
I have attached pictures of the corded tire. Note it is corded so far outside that it's actually off the tread. I thought it could be from running the tire too hard before they are fully warmed up, but then put a piece of painter's blue tape where I thought it may be rubbing and ran one session. You can see that the tape has been blackened suggesting rubbing.
I called the dealer today and they are going to call me back about the technical bulletin. One question I have is should the work under this bulletin be done under warranty or is Porsche going to try to charge me for this because it's only a problem at the track? Anyone have this done yet? Under warranty or at the owner's expense? If at owner's expense, any one have a rough cost of the work?
Old 08-02-2016, 10:17 PM
  #131
TRAKCAR
TRAKCAR's Avatar
I still think it's not from rubbing but from RWS but I could very well be wrong.
I'm paying for it and sending the bill to Porsche.
Old 08-02-2016, 10:52 PM
  #132
signes
signes's Avatar
Looks like another case of needed fender rolling (mine were rolled from the factory, April build). Haven't heard the suggestion about RWS, interesting.
Old 08-03-2016, 10:05 AM
  #133
Nizer
Nizer's Avatar
Received 1,845 Likes on 956 Posts
Doesn't look like normal cording. Keep us posted.
Old 08-03-2016, 10:20 AM
  #134
bill357
bill357's Avatar
yes please keep us posted
Old 08-03-2016, 10:31 AM
  #135
Kobalt
Kobalt's Avatar
FWIW: This is how my left rear looked before rolling the fenders:
Quick Reply: Setup numbers RS
