991 GT3, GT3RS, GT2RS and 911R 2012-2019
Setup numbers RS
Old 04-05-2017, 09:08 PM
  #526
cashed
cashed's Avatar
That was Dan at the very end! Irish was killing it out there this last weekend. Cheers!
Old 04-05-2017, 09:21 PM
  #527
C4SGRPDK
C4SGRPDK's Avatar
Originally Posted by m3irish
Here's the video I promised. 2016 GT3 RS with:
HRE R101s 19x9.5 19x12
Hoosier R7s 265/35-19 and 325/30-19
Car performed well with the nannies on and off.
Any feedback welcome.
Cheers!
It's a nice tire combo! fronts are a little wider than oem and the rear are pretty much the same width as oem.
However it does drop the car more in the rear (-1.9in) than the front (-1.1 in).
if you went with 235/345, you would retain the electronics, very slightly wider fronts then oem, much wider rears (0.9 in) and the front rear height drop would be more even, -1.7in up front and -1.9 in the rear.
Old 04-05-2017, 09:22 PM
  #528
C4SGRPDK
C4SGRPDK's Avatar
That video really makes me want to go drive COTA!
Old 04-05-2017, 11:37 PM
  #529
m3irish
m3irish's Avatar
Originally Posted by C4SGRPDK
if you went with 235/345, you would retain the electronics, .
I'm curious if you have actually read my posts.
Old 04-05-2017, 11:41 PM
  #530
m3irish
m3irish's Avatar
Originally Posted by DDWPartners Ryan
Nice Lap! I think that's my buddy Dan at the end in the white RS. What kind of mph do you hit on the back straight and front straight? I need to get out to COTA and run my RS!
Thanks for the kind words. 157 or so back and 138 front. Mark's car was definitely getting a higher MPH than mine with the exhaust mods.
Old 04-06-2017, 12:49 AM
  #531
C4SGRPDK
C4SGRPDK's Avatar
this one?
yes I have, it says you run essentially the same sizes as the GT3.
I went back through my post and I made a mistake, The people I know are running 345's tire, in the rear, not 325. My apologies, I will go back and correct that!
So to summarize,
265/325 TC & SC works as shown by m3irish
235/345 TC & SC works
265/345 TC & SC does not work.
Old 04-06-2017, 01:08 AM
  #532
m3irish
m3irish's Avatar
this one?
So to summarize,
I apologize for giving you a hard time. What do you mean when you say "the same size as the GT3"?
Wouldn't the 265/35-19 and 345/30-19 have a smaller change from stock than the 265/35-19 and 325/30-19 that I ran? I'll likely order a set of the 265/345 for my track day at the end of the month to see how that goes.
As a side note for those looking to save money going to R7s over the factory tires. Yes, you go faster and the tires run out faster. There's no savings from what I've seen. More expense actually. Although, I told, and still try to tell myself it was an economical decision to go 19s.
Old 04-06-2017, 01:42 AM
  #533
C4SGRPDK
C4SGRPDK's Avatar
Don't worry about it! We're just trying to get the right info out there to help others. The more discussion the better!
It's exactly the size I'm running on my 991 GT3.
I think the problem is not the width of the tires but the diameter.
OEM front are 27.3 inches in diameter
OEM rear are 28.7 inches in diameter
hoosiers 235 are 25.6 inches in diameter so 1.7 inches lower than stock fronts
hoosiers 265 are 26.2 inches in diameter so 1.1 inches lower than stock fronts
hoosiers 345 and 325 are 26.8 inches in diameter so 1.9 inches lower than stock rears (I know, 345's should be higher than the 325 but as per hoosier specs they are the same diameter.)
I think it's that height difference that throws off the TC and SC.
You and me both! 19's only get you a faster tire, not a much cheaper one
Old 04-06-2017, 02:00 AM
  #534
C4SGRPDK
C4SGRPDK's Avatar
Reading my post I realized you are right, since you ran 265/325 and it worked fine, there's no reason the 265/345 combo should not work since the 325 and 345 have the same diameter
let me ask around and get back to you
Old 04-06-2017, 02:24 AM
  #535
C4SGRPDK
C4SGRPDK's Avatar
found this in the mean time, maybe supremepower can give us more info on that RS as it's running 265/345?
https://web.stagram.com/p/BPz_JL3FdQ2
Old 04-09-2017, 01:59 PM
  #536
m3irish
m3irish's Avatar
Figured I'd throw out a little more data. Running the R7s (23ish psi cold and low 30's hot) with -2.7F and -2.9R camber worked ok. Front roll over looked great. The rear could use a little more roll stiffness or added camber as the wear was going further down the shoulder than I wanted. Same story with the stock Dunlops.
It did seems like the rear was struggling grip wise in steady state cornering and putting the power down on exit. Rear sway was set to full stiff with the front on full soft (front end feels good). I'm thinking about going to medium on the rear swaybar and adding another -0.3 of camber in the rear before the next track day for some added confidence.
Old 04-09-2017, 05:44 PM
  #537
EST
EST's Avatar
Manthey RS...
Interesting rear wing angle and look under the back of car as well...
Any information how this rear wing angle is achieved ? (Drilling some new holes...?)
Old 04-13-2017, 01:48 AM
  #538
TRAKCAR
TRAKCAR's Avatar
Received 1,675 Likes on 777 Posts
^^ Strange, I think it has plenty of downforce. if I add anything more it slows the car down too much in the straights..
RS time is too be had through tires and suspension me thinks..
Old 04-13-2017, 09:32 AM
  #539
EST
EST's Avatar
Good point, I am changing the suspension, not tiers (possibly trying Trofeo R's)
Old 04-13-2017, 09:41 AM
  #540
Metzeger
Metzeger's Avatar
WOW the wing angle!! possible on stock GT3 RS wing? and you see the R diffuser also?
Quick Reply: Setup numbers RS
