991 GT3, GT3RS, GT2RS and 911R 2012-2019
Weight Diff Steel Vs PCCB
Old 01-03-2016, 01:25 PM
Richard.
Richard.'s Avatar
Default Weight Diff Steel Vs PCCB
Does anyone have the exact numbers guess its around 12-14kg or 28-30lbs ?
Old 01-03-2016, 01:42 PM
LexVan
LexVan's Avatar
Received 5,406 Likes on 2,513 Posts
It's about 1/2 that IIRC. Some of the weight savings of the ceramic rotor is offset by the larger and heavier calipers.
Old 01-03-2016, 01:48 PM
Sloopy
Sloopy's Avatar
They have been weighted and still come in about 9 to 10Lb per corner even though they are larger.
Old 01-03-2016, 01:58 PM
Mike in CA
Mike in CA's Avatar
Both the standard brake package and the PCCB's use monoblock aluminum calipers; 6 piston front and 4 piston rear. I don't think there's a difference in caliper size so I believe that part is a wash.
As Sloopy mentioned, one of the brake vendors posted weights a while back for the cast iron and PCCB rotors. IIRC, total weight savings is in the range of 35-40 pounds despite the larger ceramic rotors.
Old 01-03-2016, 05:22 PM
Richard.
Richard.'s Avatar
thanks guys
Old 01-03-2016, 06:17 PM
Jimmy-D
Jimmy-D's Avatar
Received 1,457 Likes on 760 Posts
What would you say the total in weight savings is for PCCBs and LWBs. Say you save 35-40lbs with the brakes how much would you save with the LWBs?
Old 01-03-2016, 06:30 PM
mrsullivan
mrsullivan's Avatar
10 lbs, per wheel/corner, after controlling for all differences in sizes of calipers, etc. 40lbs total rotating mass. Fact. Not speculation. Porsche has put this information out now. Explicitly in writing.
Old 01-03-2016, 06:57 PM
bronson7
bronson7's Avatar
IIRC the LWB's are an additional 22lbs savings. I'm sure Mike will clarify this, he seems to have a much better memory than I.
Old 01-03-2016, 07:24 PM
Money2536
Money2536's Avatar
I think it depends on which seats we are comparing. I'd had always heard the 4-ways were 22 lb. lighter than the 18-way.
Old 01-03-2016, 10:55 PM
KA MOTORSPORT
Former Vendor
KA MOTORSPORT's Avatar
Front OE PCCB (410 x 36, 2-piece) - 15 lbs
Front OE Steel (380 x 34 2-piece co-cast) - 24 lbs
Rear OE PCCB (390 x 32, 2-piece discs) - 13.5 lbs
Rear OE Steel (380 x 30, 2-piece co-cast) - 23.5 lbs
Racing or aftermarket 2-piece upgraded 380 mm steel disc assemblies would be typically 2 lbs lighter per corner (roughly, each brand is different) than OEM Iron Co-cast discs but obviously nowhere as PCCB light.
Hope this helps.
Old 01-04-2016, 12:23 AM
loungedog
loungedog's Avatar
Hope this helps.
Great info...38 lbs of unstrung weight.
What does that equate into HP saved by the motor not having to rotate that 38 lbs of unstrung weight?
Old 01-04-2016, 12:35 AM
Drifting's Avatar
Received 1,305 Likes on 685 Posts
Can Mike, (with his awesome memory) or someone else comment on the weight savings going from the 4-way sofas to LWBs?
(I think many of those weight comparisons use the 18ways, and the 18 ways are heavier than the 4 ways)
Old 01-04-2016, 12:42 AM
ipse dixit
ipse dixit's Avatar
Received 11,657 Likes on 5,110 Posts
For the pair:
Adaptive Sport Seats 128.0 lbs.
Regular Sport Seats 97.2 lbs.
Old 01-04-2016, 12:52 AM
Mike in CA
Mike in CA's Avatar
While we are at it, how much weight do you save by putting in the new lightweight battery that was developed for the RS? This battery is also compatible with the GT3 as far as I know.
I thought I remembered but, to be honest, I checked where I had it written down to be sure...
Weight shown is for both seats combined
18 way 128 lbs
4 way 97.2 lbs
GT 2 Sport buckets 78 lbs
I don't have exact numbers for the new 991 LWB's. Keep in mind that the GT2/997 buckets had airbags but were fully manual; no motor for raising the seat. I'll guess that motors might add 5 lbs so figure maybe 82-83lbs for the new LWB's, a savings of around 15 lbs over the 4 way seats..
40lbs for PCCB's, 15lbs for the LWB's, and let's say 20lbs (or more?) for the Lion battery; a total of about 75lbs. For a 475HP, 3175lb car that's the equivalent of an additional 11HP plus the benefits of lower sprung and unsprung weight.
Old 01-04-2016, 12:58 AM
bronson7
bronson7's Avatar
My memory was close but, to be honest, I checked where I had it written down to be sure...
18 way 128 lbs
4 way 97.2 lbs
I don't have exact numbers for the new 991 LWB's. Keep in mind that the GT2/997 buckets had airbags but were fully manual; no motor for raising the seat. I'll guess that a motor might add 5 lbs so figure maybe 82-83lbs for the new LWB's, a savings of around 15 lbs over the 4 way seats..
Mike, thought I would send you a thank you for the info. Just finished watching the football game now off to bed.
Quick Reply: Weight Diff Steel Vs PCCB
