991 GT3, GT3RS, GT2RS and 911R 2012-2019
FVD Brombacher "Full" Cat-Back Exhaust!
Old 04-24-2015, 10:08 AM
  #76
NelsonF
NelsonF's Avatar
Originally Posted by MJSpeed
^^You're welcome brother. Anything else you need, let me know. If anyone else is interested, let me know.
CheeRS,
MJSPEED
I believe this is the ticket! I think it's the same solution that was finally determined as optimum overall on the 997 GT3's. Waiting to hear it on Money's car. Then also determine if the the header/200 cell cat combo make a big diff. Wondering if this center muffler will hold up without cracking on tracked cars?
Old 04-24-2015, 01:16 PM
  #77
Jimmy-D
Jimmy-D's Avatar
Received 1,459 Likes on 762 Posts
With the new center muffler can you still use the SW 1000 mm tailpipes??
Old 04-24-2015, 01:19 PM
  #78
Jimmy-D
Jimmy-D's Avatar
"After talking with FVD and some long-time, knowledgeable 911 guys, I learned that I did it backwards. I should be replacing the side mufflers with a straight pipe. Then, to change to tone, replace the the factory center muffler with a tune M&M center muffler. The cheaper route would be just cap the factory center muffler and get some side muffler/valve delete pipes. I want to change the character and improve the sound of the car, so I spent the extra money to have them produce a center muffler for me."
Money - Are they producing a center muffler just for you or they have one for distribution?
Old 04-24-2015, 01:57 PM
  #79
Money2536
Money2536's Avatar
No, the M&M muffler has tailpipes integrated into it.
Old 04-24-2015, 01:58 PM
  #80
Money2536
Money2536's Avatar
Once I get this figured out, you'll be able to order it. FVD may end up stocking them if it's as good as I hope it will be. I'm editing video right now of the side mufflers with the bypass.
Old 04-24-2015, 02:10 PM
  #81
LAGinz
LAGinz's Avatar
So is this the same general concept as the BBI system?
Old 04-24-2015, 02:17 PM
  #82
Money2536
Money2536's Avatar
Yes. The only difference is replacing the center muffler.
Old 04-24-2015, 05:57 PM
  #83
Money2536
Money2536's Avatar
Old 04-24-2015, 09:29 PM
  #84
Shrevehorn
Shrevehorn's Avatar
Will comment later, can hear audio but video frozen.
BTW, plate looks way better with space after 9K. Your larger gt3 decal appears more centered.
Old 04-25-2015, 01:24 AM
  #85
Alan C.
Alan C.'s Avatar
Received 1,054 Likes on 542 Posts
Matt, Thanks for putting the video together. Sounds pretty good to me. It appears to solve the annoying sound transition from the valves, no valves! Would say this system is quieter than the Sharkwerks?
Old 04-25-2015, 08:02 AM
  #86
Money2536
Money2536's Avatar
It is quite a bit quieter than the SW bypass and factory side mufflers. That's why I took it off.
Quick Reply: FVD Brombacher "Full" Cat-Back Exhaust!
