Essex/AP Racing 2-piece Brake Discs and Ferodo Racing Brake Pads for 991 GT3!
#91
I'm running a 987.2 spec Cayman S track car that's 2,700lbs....I was thinking of using a pad with a little more bite in the rear versus the front to get rid of some slight ABS instances. Does you recommend recommend the DS1.11 in the front and DSUNO in the rears to get a little more brake bias for the rear? Also, I'm running the larger Girodiscs rotors in the front (340mm) and rear (325mm)...does AP Racing make these larger rotors for the 987.2 Cayman S?
#92
Basic Sponsor
On the discs, yes, we are working on expanding our line of two-piece discs for non-GT vehicles. We just released our two-piece AP Racing discs for the other 991 trim levels, and we're evaluating other models as well (including the Cayman and Boxster). Please stay tuned, and feel free to jeff.ritter@essexparts.com at any time. Thanks!
'09 Carrera 2S, '08 Boxster LE (orange), '91 Acura NSX, Tesla Model 3 Performance, Fiesta ST
Jeff Ritter
Mgr. High Performance Division, Essex Parts Services
Essex Designed AP Racing Radi-CAL Competition Brake Kits & 2-piece J Hook Discs
Spiegler Stainless Steel Brake Lines
704-824-6030
![](https://rennlist.com/forums/signaturepics/sigpic110137_8.gif)
Jeff Ritter
704-824-6030
#93
Basic Sponsor
Basic Sponsor
Just ran the DS3.12's this past weekend on my 991.2 GT3.
Previously I had been running the DS1.11's with good success and rotor longevity.
Well.....so far so good. Easy brake modulation, no ABS activation, or rotor issues.
Here's the interesting objective findings:
Solo DL 2 data analysis of brake pressure for identical zones on a known local track are consistently decreased by 300-400 psi on heavy braking (end of straights), and decreased by approximately 100-150 for less aggressive braking areas of the track.
Very confident braking from the out lap if the system was warm from a previous run (within an hour).
Good even transfer of pad material to disc. Absolutely no shuttering.
Minimal to no fade after 30 minute sessions.
Only bad thing is that I need to re-train my brain and foot so as to compensate for the decreased pedal application. I also lost .5 seconds per lap because I was over slowing into the initial turn in from a long straight. I'll fix that next time out.
#97
Basic Sponsor
Thank you very much for the data and feedback. We really appreciate it! Your comments make sense, and they match our expectations based on dyno and data from other customers. Positive impressions have been pouring in, and we're definitely excited about what we've seen it do thus far. Once people wrap their head around the slightly higher mu, they really begin to exploit this compound.
Have you noticed any squealing noise? The odd thing we keep hearing from customers is that the DS3.12 is completely silent. I noticed this firsthand on my Corvette track car.
Thanks again!
FYI...we only have a few sets of the second batch of these pads remaining on the shelf and ready to ship if anyone wants to try them. More are on order, but no ETA on those yet.
Thanks again!
#98
#100
Basic Sponsor
Thanks for your report. The fact they are quiet is an added bonus. I have these pads (DS3.12) in stock but they are not yet on our website. Call to order.
Clark
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: chamerly@apexperformance.net
www.apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist-10 on your next order or mention Rennlist during your phone order.
PCA Club Racing - National Sponsor
Clark
ApexPerformance.net
#101
#103
I'm trying to quickly sift through all the 991.2 track prep threads but meanwhile for a few brake related questions, this might be the right thread:
DS3.12 is meant to be the newer & better DS1.11, or it's a different compound and will coexist w the 1.11?
Is the jury still out on the AP vs Giro rotors? For the 991.1/2 GT3, they both seem to be similar price, both 380mm? Would the Tarett brake caliper studs meant for the Giros also work w the APs? Any advantages/disadvantages specific to either?
Finally - is the OEM brake pad & rotor & fluid setup usable at all at the track? I remember the Carrera pads melted pretty fast, fluid was definitely a no go, and rotors were shot fairly quick as well as they develop cracks between the drilled holes. I'm wondering whether the optimal behavior is to pull the OEM pads rotors from day one, preserve those and start w the track appropriate rotor+pad+Motul 600?
#104
The Tarett brake caliper studs just replace the OEM caliper bolts, so they are generally compatible with anything that is compatible with the OEM calipers (including both the AP and the Girodisc rotors).
Note that Girodisc now sells their own brake caliper stud kit at the same price as the Tarett parts, but they actually use a fully stainless front stud in addition to the fully stainless rear stud (while Tarett uses an OEM cup car coated steel stud in the front, which can rust over time).
While the stock rotors develop cracks, so do the AP and Girodisc rotors even relatively early into their lifetimes, so I wouldn't expect that to go away with any of the iron rotor setups.
#105
They are certainly different, and my understanding is they will continue to coexist.
There are fans of both rotors, and they both seem like solid hardware. The main differences I'm aware of are the AP rotors use J-hook slots, while the Girodiscs use straight slots. I've had some whirring under braking from the J-hooks sliding past the pad surface, but I haven't heard if Girodisc users experience similar things.
I've run OEM fluid at the track and it's been fine under some pretty heavy use, but ultimately I've switched over to Castrol SRF.
