GT3 Tools and Gear
Hi guys,
As my GT3 is on a boat, I started ordering parts and tools for it. In doing so, I've been reading lots of threads, which is very tedious. I was thinking it would be nice to have a single source for the most common items, and even links to where to buy some of them. I'll start out with the things I've purchased, but please reply below with any other tools, consumables, or miscellaneous items that you use on your GT3. I'll update this main post to include them all.
Wheels:
Center Lock Removal Nut (comes with car) - http://www.suncoastparts.com/product...1GT3CHASSISACC
Wheel Alignment Tool
Rennling - http://www.rennline.com/Centerlock-W...fo/T06/DELRIN/
3RAuto - http://www.3rauto.com/departments/parts/3r_parts/
Center Lock Grease - http://www.suncoastparts.com/product/04302000.html
Bulk - https://www.motobins.co.uk/displayfi...search=1&go=GO
Jacks
Brunnhoelzl (** need model info) - http://www.brunnhoelzl.com/home.html
Jackpoint Jack Stands (***need model info) - http://www.jackpointjackstands.com
Breaker Bar and Torque Wrench - http://www.tooltopia.com/precision-i...s-c4d600f.aspx
Breaker Bar -
Torque Multiplier (If not using above) - http://buy1.snapon.com/catalog/item....e=&dir=catalog
Air Compressor - fits in frunk - http://www.sears.com/craftsman-6-gal...1&blockType=G1
Replacement Couplers -
Legacy A73458D Color Connex Type D 14 Piece. 1/4 in. Red Coupler and Plug Kit - Hydraulic Couplings - Amazon.com
Goodyear Hose -
Goodyear EP 46502 3/8-Inch by 50-Feet 250 PSI Rubber Air Hose with 1/4-Inch MNPT Ends - Air Tool Hoses - Amazon.com
Basic Air Chuck -
Tire Inflator w/ Gauge - available cheaper from other resellers -
Air Tank - http://www.prestacycle.com/buy_bicyc...bike_tools.php - 30CF has been suggested
Tires
Michelin Pilot Sport Cup 2 - http://www.tirerack.com/tires/tires....3&autoModClar=
Dunlop Sport Maxx Race - http://www.tirerack.com/tires/tires....3&autoModClar=
Pirelli P Zero Trofeo R - http://www.bobwoodmantires.com/p-zero-trofeo/
Winter Tires - http://www.tirerack.com/tires/tires....pin+PA4+N-Spec
Brakes
Ferodo Track Pads and AP Racing Rotors - http://www.apexperformance.net
Pads - PFC11 (Track use)
http://www.apexperformance.net/prod-2559.htm
http://www.apexperformance.net/prod-2558.htm
Overview: http://www.apexperformance.net/CartG...es-porsche.asp
Brake Fluid - RBF600 - http://www.apexperformance.net/prod-1493.htm
Brake Caliper Stud Kit - http://www.tarett.com/items/991-981-...csk-detail.htm
Brake Pad Spreaders
Generic (I use this one) -
GiroDisc - http://store.trgparts.com/girodisc-b...der-p9987.aspx
Lisle -
Brake Depressor
Irwin -
Amazon.com: IRWIN Tools QUICK-GRIP XP600 Series One-Handed Bar Clamp and Spreader, 24-Inch (2021424N): Home Improvement
or
Amazon.com: IRWIN Tools QUICK-GRIP SL300 Series One-Handed Bar Clamp and Spreader, 24-Inch (524QCN): Home Improvement
Lisle -
Thexton -
Caliper Piston Rebuild (Including high heat) - http://www.racingbrake.com/category-s/7185.htm
Track Accessories
Tow Hook
http://www.rennline.com/Rennline-Fol...info/E13%2E09/
GoProMount - http://www.rennline.com/Rennline-GoP...ductinfo/PH01/
Pyrometer (Tire temp testing) -
Tire Pressure Gauge - http://www.longacreracing.com/products.aspx?prodid=7352
Analog - http://www.longacreracing.com/produc...16&prodid=7327
Roll Cages
Alekshop - http://alekshop.com/products/porsche...91_harness_bar
GMG - https://rennlist.com/forums/991-gt3/...available.html
Cantrell - http://www.cantrellmotorsport.com/in...ategory_id=398
Exhaust
Sharkwerks - Bypass, Track Exhaust, Tips - http://www.sharkwerks.com/products.p...8&type=Exhaust
GMG - Exhaust, Headers - https://rennlist.com/forums/991-gt3/...ired-wrap.html
Cargraphic - Bypass, Exhaust, Tips - http://www.cargraphicts.com/en/produ...odels/991-gt3/
iPE - Exhaust, Tips - http://www.ipe-f1.com/products.php?b...86552864342025
Akrapovic - Exhaust - http://www.akrapovic.com/#!/car/prod...60&yearId=3864
Suspension
Control Arm Shims - http://www.tarett.com/items/991-981-...him-detail.htm
Miscellaneous
Oil - or
http://www.walmart.com/ip/Mobil-1-0W...ype=10&veh=aff
Oil Filter - http://www.suncoastparts.com/product...GT3MAINTENANCE
Clear Side Märkers
Regular - http://www.suncoastparts.com/product...GT3EXTERIORACC
LED - http://www.suncoastparts.com/product...GT3EXTERIORACC
Clear Tail Lights - http://www.suncoastparts.com/product...GT3EXTERIORACC
Trim and Decals - http://www.suncoastparts.com/categor...C&show=29.html
Front Lip - http://www.suncoastparts.com/product...GT3EXTERIORACC
Mobile Phone Holder - http://www.kenu.com/products/airframe-plus
Dash Mounts (Phone, camera, etc) - RAM Mounts
Battery Charger -
Battery Maintainer -
Race Ramps -
Spark Plug Change Tools
Hazet HZ4766-2 Spark Plug Wrench:
Snap On FXWK4 Extension: https://store.snapon.com/Extensions-...--P640850.aspx
Wheels:
Jacks
Breaker Bar -
![Legacy A73458D Color Connex Type D 14 Piece. 1/4 in. Red Coupler and Plug Kit - Hydraulic Couplings - Amazon.com](https://rennlist.com/forums/images/misc/amazon_icon.gif)
Goodyear Hose -
![Goodyear EP 46502 3/8-Inch by 50-Feet 250 PSI Rubber Air Hose with 1/4-Inch MNPT Ends - Air Tool Hoses - Amazon.com](https://rennlist.com/forums/images/misc/amazon_icon.gif)
Basic Air Chuck -
Tires
Brakes
Brake Pad Spreaders
Lisle -
Brake Depressor
Irwin -
![Amazon.com: IRWIN Tools QUICK-GRIP XP600 Series One-Handed Bar Clamp and Spreader, 24-Inch (2021424N): Home Improvement](https://rennlist.com/forums/images/misc/amazon_icon.gif)
or
![Amazon.com: IRWIN Tools QUICK-GRIP SL300 Series One-Handed Bar Clamp and Spreader, 24-Inch (524QCN): Home Improvement](https://rennlist.com/forums/images/misc/amazon_icon.gif)
Lisle -
Thexton -
Track Accessories
Tow Hook
Roll Cages
Exhaust
Suspension
Miscellaneous
Oil - or
Clear Side Märkers
Battery Charger -
Race Ramps -
8202632 (06-08-2020)
Major
I have been buying Optimoly TA paste in tins from Motobins. https://www.motobins.co.uk part# 95805. This is much more economical than the tubes.
Major
I also added exhausts. I will add anything else anyone posts, but I'll probably stop replying to all of them so the thread can remain as suggestions. I think the only thing I would avoid if rims.
Be sure to buy an extra CL socket. It will make it much easier on you if you have the socket already on the breaker bar and torque wrench. An extra set of CL nuts is quite nice too. That way, you can always have a spare set ready to go, pre-lubed. And don't even bother with that stupid truck brake pedal depressor. I bought one and it never worked well enough and then promptly broke. The Irwin clamp is perfect. And last, but not least, buy some surgical gloves. They keep that nasty Optomoly paste off your hands.
I'm old-school, I like the easy to read analog tire gauge:
http://www.longacreracing.com/produc...2%BD”+lb
Cup car shims, Yes ...........
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,415 Likes
