991 GT3, GT3RS, GT2RS and 911R 2012-2019
Consolidated 991RS thread
Old 08-02-2015, 12:44 AM
  #9076
<3mph
<3mph's Avatar
UV posted on PH... just stunning!!
http://www.pistonheads.com/gassing/t...S+in+Guildford
Old 08-02-2015, 08:57 AM
  #9077
Peterfirst
Peterfirst's Avatar
Originally Posted by Macca
That's interesting. Mine happened in the evening after being at the track where I spun the car in the wet onto the grass then hosed it off. I did a few extra sessions then parked it up in the rain while we had a few beers and a BBQ. Maybe it does have something to do with water. I wonder if Peters issue started in the wet?
Hi Mark:
No - started when it was bone dry. First on a Sunday evening. Took miles on end to get temp up and I wass already having the feeling that this could be the thermostat. Then Wednesday after that first time it happened again in the morning that it took a endless time ot reach oil/water temps as normal.
Then on the way back (I did a 500 km round trip that day) the water temp reading error poped up (including the message that it is possible to drive on).
Now car is at the dealer and they said it is most likely the thermostat - which I also think it is. Hope to have car back on next Tuesday then I will report.
Nice weekend to everyone
Peter
Old 08-03-2015, 04:06 AM
  #9078
Raven 666
Raven 666's Avatar
Looks like Ultra Violet is a very light sensitive colour ,,,,the front of the car looks blue in that image ,,,,,,fantastic ,,,thank you for posting the image
Old 08-03-2015, 04:44 AM
  #9079
JCO
JCO's Avatar
Default Trackday 02.08.15 Rudskogen Raceway, Norway
Old 08-03-2015, 07:20 AM
  #9080
Bodhi_954
Bodhi_954's Avatar
Default Break-in procedure
According to Preuniger the break-in makes a noticeable difference.
He recommends max 5k rpm the first 500km of driving. Varying rpms - but not too much stop/start. After 500km increase 500 rpm each 100km up to 1.000kms and then hold off on the last 1.000 rpms until at 1.500kms.
Just a recommendation ...
Old 08-03-2015, 09:58 AM
  #9081
WazRS
WazRS's Avatar
Great article of the RS on TopGear Magazine! Makes the wait even worse!
Quoting:
'...this is not a muscle car. This is a precision instrument'
'...[curve' speed of attack is almost irrelevant. It doesnt understeer'
'... double paddle neutral ****: Hero Mode!'
Just one thing i didnt grasp, I know the maximum lateral g's cars can pull is 1.4-1.6g and the RS is recording 1.75!! Is this really possible?
Wael
Old 08-03-2015, 11:04 AM
  #9082
Kobalt
Kobalt's Avatar
Curves with camber allows higher g's.
Old 08-03-2015, 11:31 AM
  #9083
jo_ker
jo_ker's Avatar
sure that "banked turns" make higher lateral g-force possible?
higher curve-speeds - yes, clear.
but pure lateral g-force fron the (angular) car point of view?
may you are correct cause the car is in an angle - so it can work also (purely lateral - seen from the angular car point of view) against the gravity of earth - which it can´t in a flat corner.
Old 08-03-2015, 11:47 AM
  #9084
WazRS
WazRS's Avatar
We need a physicist in the forums!
Old 08-03-2015, 01:07 PM
  #9085
Kobalt
Kobalt's Avatar
Default Consolidated 991RS thread
I do 1.35g in Adenauer Forst (Nürburgring). Yes it is banked. (In a 997.1 gt3).
I do not do that when it flat without spinning
Old 08-03-2015, 04:31 PM
  #9086
WazRS
WazRS's Avatar
At 1.76g's.... we will be needing this from Porsche Driver Selection:
Wael
Old 08-03-2015, 06:39 PM
  #9087
Macca
Macca's Avatar
I think those are peak Gs not sustained. The maximum sustained Gs I've seen with the 991 GT3 on the track via the Aim Solo dL (calibrated) is around 1.34 in the GT3 with a peak of 1.68 - the in car showed 1.38 & 1.72 (I don't think it's calibrated as well). orthoJoe, max and others have observed similar on another thread. Peak can be affected by sudden bumps and quick changes of direction etc. it's the sustained Gs you need to be comparing. The French track test compares both cars in the same track (albeit 12 months apart) and you can bring up both SportAuto reports for both cars and compare the Gs for Hokeinhiem short circuit if you want more data points. The RS pulls more G in the faster corners and interestingly the GT3 more in a couple of the slower ones. It's subjective because conditions (weather tyres etc) are obviously different between the tests and the angle of attack and the line that works for one car may be different than the other. There is no doubt the RS is able to handle more lateral G in the majority of corners but the delta on constant G is more likely 0.4-0-.5 G...
here is a screenshot from a friend in Europe GT3 G meter. This I think was one of the European circuits.
Old 08-05-2015, 04:37 AM
  #9088
ScottKelly911
ScottKelly911's Avatar
just curious if anyone is going to paint the rear lower rubber "diffuser" part of the rear bumper to make the car appear lower? It just looks weird to me with it black like the car is riding way too high.
Non-painted stock look
Painted body color
Old 08-05-2015, 03:25 PM
  #9089
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
In a banked turn the Gs will be a bit off; ie more forces become directed DOWN or at a 45 rather than purely sideways...so the banked turn measurement will be a little wonky.
It's a really a trip driving at speed at Daytona, for example...well, it's like driving in a fishbowl where you need to look UP more than ahead...it's so weird
Old 08-06-2015, 08:39 PM
  #9090
Nizer
Nizer's Avatar
Received 1,886 Likes on 972 Posts
Reposts?
Quick Reply: Consolidated 991RS thread
