Bye Bye 991 TTS, welcome GT3
#46
Very nice looking car! Hope to see it sometime at MSR, ECR, etc. Being a Vette guy and currently owning a C6 ZR1 that I track frequently, I've only been considering the C7 Z06 or ZR1 as a replacement. But honestly, I really think I'm going to have to seriously consider a 991 GT3 or GT3 RS before making a final decision. It's the only other car that interests me besides the Z grade Vettes.
Again, beautiful car and I hope I can hear that 9k wail sometime at the track.
#48
Sam,
I test drove the 991TTS and did not like the drive .... I am on list for a GT3.
Very curious to know your impression on TTS versus GT3 Torque on straight line.
Mine will be a DD with almost no tracking - coming from a 997 AWE Tuned 750HP Turbo I am wondering if you miss the straight line torque of the 991TTS when you drive the GT3 on normal roads.
Thanks in advance.
Thanks in advance.
#49
PS: I paint my own. One coat of primer, then two coats of paint, then two coats of clear. All from spray cans from the Home Depot.
#50
Might have to move the GT3 sign again with the larger PORSCHE ? The larger GT3 looks so much better.Might look too busy with the larger PORSCHE. I would try the GT3 alone and then see if PORSCHE is really needed there. can you provide the color details from HD?brand, etc.
#51
I need rear seats to get the minister of finance's approval (wife).
#53
Sorry, am I misunderstanding? I thought the GT3 didn't have rear seats? That is the primary reason why I didn't buy one. (Well, and the budget, but at least I can work towards resolving that part of the problem).
#54
Congrats on the new wheels Sam. You just might be the first owner that can give us accurate relative laptimes of the TTS vs GT3 on the same track and Non-Pro driver's impression of handling differences between the 2 cars. The different tires will undoubtedly be a factor, but I'll be paying rapt attention to your comments and will greatly appreciate the coming feedback.
#55
#56
While on the subject, I have a tire pressure question. I never ran R tires before. For my Pirelli P Zero or Michelin PSS on the C4S and TTS, the best hot pressure for me was 33 front and 37 rear. I know that R tires run at lower oressures. What hot pressures have people used on 997 GT3s with R tires before? I am guessing 30 F and 32 R????
#58
#59
Hi Sam,
This was the direct response I received from Pirelli IRT my R-Comp Trofeos running on my Turbo S. If I let the pressures build to around 33+ PSI they started to get slippery. I know this is a totally different tire however maybe this will at least give you a data-point.
Walt-In Tokyo
"The Trofeo R as a DE / Track tire has the construction llike a slick and works at hot pressures like a slick.
2 bar hot ( around 30 psi ) is what Pirelli is looking to see on this tire. To achieve this hot pressure the customer
Should set the tires cold to 1.6 bar and then go out for 2 or 3 laps to get the tires warmed up being very careful on
The frist out lap no to go off the circuit or hit any big curbs as the tire has not come up in temp / pressure.
Then go back to pit lane an check the hot psi’s. and adjust them accordingly.
Now if by chance you are running the tires on a road course / oval with some periods of running the car on a
Banked surface ( Daytona, Fontana, Kansas Speedway, etc. etc. ) then you will need to run higher hot pressures
To due the loading of the tires in the banking.
After you DE / track session is finished for the day don’t forget to inflate you tires back to the street pressures before
You leave the racetrack."
Walt-In Tokyo
#60
Hi Sam,
Walt-In Tokyo
Walt-In Tokyo
