GT3 Race Track Manual
Quick scan of the new racetrack use manual for the GT3. Has the setup and maintenance schedule included.
https://drive.google.com/file/d/0B95...it?usp=sharing
(sorry alternate pages are upside down - tried to get the best quality from the scanner and it was the only way to get it to work)
Food for thought in here for sure.
No slicks allowed... Sad indeed.
Thanks for posting. At least they are now being more thorough with whats required or expected with track use...
Thx for posting! So the only warranty voiding language I saw in there was around slicks, wheel sizing and maint intervals. I'm assuming the 997 manual did not have a similar statement around slicks?
DOT R Hoosiers would appear to pass this black and white warning then (if they are even available in stock sizes someday)
Nope. Although not confirmed, I think the RWS can't keep up with the huge forces created with slicks. My guess as to why the RS is going without RWS (and presumably with slicks allowed). Just a guess...
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 3,908 Likes
This is excellent, makes me more inclined to buy the car for track use. Some notes:
- They don't mention using racing brake fluid, but I'd certainly do that. And flush is needed no farther apart than every few events, so many times in 12 months if tracking often.
- They imply that the stock brake pads are adequate for track use. That would surprise me, unless the stock pads are quite different from typical street pads.
- My interpretation is that something like an R6 would be OK. But there may not be many tire options for this wheel size for quite a while.
- I like that the alignment is already set up to be a reasonable compromise between street and track, and that it's apparently easily adjusted.
- Replacement of parts on their schedule won't be cheap, but it's great that they provide a schedule.
- I've always taken air out of cold tires so that I'd wind up with the right hot pressures, and I've seen most everyone else doing that. But I give a few laps for the pressures to come up before really hammering it.
- Overall, this info increases my confidence that Porsche has done what it takes to make this car trackworthy, and stands behind that with warranty.
The primary manual would have warranty information. Wonder what that says? Although I have an idea.
I think this supplement makes it imperative to keep meticulous records of any track use to document compliance. Now it's just too easy for them to say - of course the wheel fell off, you didn't follow the protocol.
This supplement does not mention any warranty policy at all. It's just the required service, maintenance, and inspection intervals for track use, should you assume that risk.
Under certain circumstances the warranty may be voided if these aspects are not taken into consideration."
The direct implication of the wording is that if the additional service aspects ARE followed, the warranty will remain in force. A big step up from the previous "track events will void the warranty" language and very welcome news.
