gt3 rs 991.1 Mathey Aero
So just a simple question , purchased the kw 4way - 3way shocker set up Mathey sells for 991.2 gt3rs . As im going to run the Manthey big wing that they run on the 991.2 rs , Mathey is now fitting this Aero set up on 991.1 . So with this setup is it possible to run the carbon fibre sway bars found on the 991.2 . as the shocker set up is the same . So in theory if I run the kw 4way 3way shocks as found on 991.2 , I should be able to run the carbon fibre sway bars found on a 991.2 but retro fit them to a 991.1 rs as well and save a little weight . Would any one know about this .
In theory yes - correct.
The following 2 users liked this post by TDT:
jap10 (06-09-2023),
Larry Cable (06-09-2023)
note the MR kits are now becoming available from dealerships via techquipment
p.s I'm not sure its worth the $'s to substitute the CF sways for the OEM metal - what will that save, a kilo - just take a dump before driving!
Rick GT3 (06-09-2023)
Larry Cable (06-10-2023)
