Hi, I just picked up a 911.2 GT3, however all 3 grills were cut to fit a laser jammer / detector. I tried to look around but couldn't find much info on 991.2 GT3 grill part numbers. I have only found info on 991.1 which are 991-504-787-90, 991-504-788-90
Anyone know what is the part number for the Left, Right and Center grill for 991.2 GT3?
Found the part numbers if anyone needs:
99150571380 - Left (Driver)
99150571480 - Right (Passenger)
99150571180 - Center
Thank you! I found those earlier, but I am still super curious if other people have the exact part numbers. It should be a little bit cheaper vs ordering from Suncoast Parts.
Edit: Just found them, seems like these are the part numbers
Suncoast is the least expensive option if you are looking for new OEM you may be able to get used from a yard like LA Dismantler
I did some research and ordered some from Rose Passion, which seems like some EU Porsche Parts site. Was around ~$150 cheaper to get all three grills, so hopefully no issues.
Suncoast is very rarely the cheapest option. As a matter of fact, they don’t publish part numbers so you can’t easily find and shop around for a lower price (which is easy as soon as you have the PN).
Its not that hard to find part numbers on your own. Where have you been able to find New OEM stock for less than Suncoast? It would be a great resource for the rest of the board. Thank you in advance.
Everywhere for the most part - sunset, getporscheparts, gaudin, or just about any dealership. Suncoast does not post part numbers for a reason, and they make it easily accessible as convenience is their value.
Do you have to take the bumper off to swap them out? If so, how difficult is that?
Yes you do, the center one is very easy. The side grilles are somewhat more difficult, but doable. Something I learned is that when the bumper is off, you should be able to take off the air blades and slide in the grille in.
