Bad Valves or Grenaded Center Muffler?
FIXED (THANS SOUL!) Bad Valves or Grenaded Center Muffler?
991.2 GT3RS. Out for a drive today. Heard a weird fart/woof sound. Exhaust note got super deep and droney. Sounds like a riced-out Honda now. Valve button does nothing. Hard to see, but doesn't look like the valves are actually moving when button pressed, either. Vacuum lines appear connected but it's hard to tell. Running Soul side-bypass. Does this sound like a cracked/grenaded center muffler or something else?
If the center muffler gets a crack, wouldn't the valve button still change the sound slightly, as they are still re-routing exhaust through different parts of the muffler? Or there could be an internal crack rather than the external walls of the muffler...
Hard to be sure, but I also thought I smelled sulfur/rotten eggs once or twice.
EDIT: FIXED
It was a bad valve. Soul Performance took care of me.
EDIT: FIXED
Doesn't sound like an exhaust leak (unless there's a hole in the center muffler that I can't see).
Valve vacuum lines appear connected. But hard to see without getting the car in the air. Do both valves' vacuum lines meet at one junction or are they connected to separate sources? Because maybe there's no vacuum for some reason, even with the rubber lines connected? As in... maybe the hard line(s) got disconnected or broken somewhere farther up the chain?
Simple guess is the vacuum line popped off on one side. They both eventually combine to one source so if only one popped it likely isn’t getting enough to move the valves. Easy fix if that’s what it is, you can see where they connect to the valves if you lay down next to the rear bumper on each side.
I checked the vacuum lines. At least all of the connections I can see from under the car. They are all connected. So if there is a vacuum problem, it's happening farther up the chain somewhere.
PSE button does nothing. Valves don't move when pressed. Under normal operation, they are supposed to actuate when car is idling.
I think there is an electronic vacuum device, look here
https://www.sharkwerks.com/tech-arti...imit-at-laguna
Have you checked the vacuum lines up top? You have to pull the 2 center fans but it's pretty easy. I had an issue with the lines up there that caused the valves not to work. I can take a picture later if that would help.
How does that fan housing come off? Just pull?
Ok, so I forgot that the cover is one piece. Here are the photos. Check the white valves. Those are part of the system. Hope that helps!
The cover has 8 contact points, 4 on each fan.
The fans each have 3 contact points. 2 on top, one close.
The 2 partially white valves are part of the system.
Hmmm, thank you for that!
I have an RS, though. And the fan module and underlying components are slightly different. I'll have a look, but I'm gonna bring it to Porsche tomorrow as well.
spyderbret (05-31-2022)
You have a 3RS which means your center muffler is titanium. Center muffler damage happened to more than a few people running side bypass pipes on the titanium mufflers. If you replace it with a GT3 muffler I am confident you will fix the problem, unfortunately while picking up some weight.
