I've got my first track day with my .1 GT3 coming up at the end of March. I am not unfamiliar with HPDEs or W2W racing so I'm aware of the general items to bring. However, I am unfamiliar with GT3s and Porsches in general, as this is my first, I have only owned it for a few months, and have not had the opportunity to wrench on it myself.
That being said, I'm curious what folks on here bring along to track days. What specific tools, service items, and parts do you guys bring along?
For what it's worth, this is a one-day event, and should any serious failures happen, my disposition is probably to load the car back up and bring it home rather than do major service in the field.
Thanks in advance!
Assuming your car is in fine condition, you don’t need much:
pressure gauge
oil/funnel
the removal tool for the centerlock caps is handy
glass cleaner
tire inflator
Nothing really special needed unless you are swapping wheels at the track.
Not all tracks have fuel, so be sure you’ll have plenty. GoPro if you’re so inclined. In a garage or outside? Comfortable chair, shade, cooler, hat, etc.
OP: congrats. First track day is a big and special experience.
Do not bother with bringing too much or going all-out on tech items. You have a lot to digest so really, focus on your driving.
I would only bother with a tire gauge and pre-install your tow hooks front and back. Don't bother with wheel change blah blah blah. That's way down the road for you.
I assume you're all sorted with safety: helmet, gloves. If not, sort those out pronto.
Don't forget to enjoy. It's a journey to savor at each step!!
p.s. you'll have a LOT of people offering all sorts of info to you. Tire pressures, how to trail brake, shift points, lines thru corners blah blah blah till the cows come home. Don't be too fussed--all that will come to you in due course if you enjoy yourself
OP said its his first trackday in his GT3, not overall.
Thag being said, GT3 is the ultimate show up and drive car. And wrenching on it is annoying encough that I didn't even bother trying at the track. Just have an up to date AAA membership in case you need to tow it back home.
So... Bring a helmet, tire pressure gauage, compressor to fill air back up, and ensure your tow hooks are present. The low friction to just doing a track day is the best part about the GT3.
Some specific GT3 things to be aware of that I recall from my first day with a 991.1:
if you're required to run windows down as many groups do, you may experience some buffeting at speed. There are solutions- like the stick on winglets, I think I had Blackmill on mine. For one day probably not an issue for most, but may want to address if you track it a lot.
The low fuel warning will come on at 50 mi range remaining. depending on your driving it may come on with near 1/2 tank remaining. Just toggle it off.
If you use race circuit mode in TPMS, you need to re-select it each time you start the car. otherwise it will go into learning mode.
Good idea to check centerlock torque ahead of time and be sure the center pins are fully engaged- popped out to cover the internal splines.
I drove in sport mode, exhaust open, and PDK in auto (but that's a personal choice). if wet I had PASM in normal mode.
Have fun, great car for a HPDE.
Edit- oil mentioned above and I agree, mine would use some and usually had to top up on a weekend event. For a single day may not need to. If I recall, the manual says recommended level is 3/4 on the range in the display.
Thanks a ton for the information, guys. Glad to hear that the cars are typically good to go. In that case in addition to the basics I'll just be sure to bring along a standard metric/SAE tool set for any light issues or rental trailer issues that may arise.
Is always a good idea to have the dealer or a reputable race shop do a good tech inspection to make sure tires, brakes, fluids are all up to the task. Like others have said, if maintained regularly these cars are pretty bullet proof.
