992 GT3 PDK shifter in 991 GT3?
#46
Insert a small "L" shape pry bar in hole around the PDK lever and gently pull up to release the plastic surrounding trim (so in this way you can avoid to remove other interior trims), disconnect the electrical cable from the door lock/hazard switch with the help of a small flat screw driver.
Swap the door lock/hazard switches in the new plastic trim and install back in the console.
Insert the new **** with the alcantara boot lifted up, lock the lower collar by rotate it CW, lower and install in place the boot.
Done.
RDCR (09-02-2022)
FourT6and2 (09-02-2022)
#49
Put PDK in D, rotate the locking collar in lower part of the shifter lever CCW to unlock the ****, pull straight up on the lever and the entire **** will come right off.
Done.
Done.
#52
The parts came in and it was a 5 minute install. Thanks @Diego7K ! I decided to switch the console to leather to match. Here are some pictures. Bought a GT4 steering wheel to complete the look. Waiting for the airbag...
BTW after talkimg to Suncoast I used https://www.suncoastparts.com/produc...rtknobpdk.html which included the plastic trim around the hazards and door locks. If you use this, it's the same price AND includes the trim piece so you do not need to order it separately.
#53
Ordered last Wednesday, received yesterday, installed today. This is the GT4RS **** if you are okay with the artic grey (very similar to silver but a bit darker which is fine). For those of you waiting years for suncoast, order through your dealer parts department and tell them that you’ll prepay the $80 freight for expedited ordering (this places you on a priority for shipment). That is, of course, if you are willing to go with artic grey or have it restitched yourself.
Part numbers are:
982-713-120-A-P02 (The artic grey stitched **** and boot)
991-553-651-01-A05 (the button surround trim.
Part numbers are:
#54
Suncoast really is the worst. I cancelled my order.
#56
I just ordered one from P of Monterey based on thescout13's post above and was told the same leadtime. As soon as P of M gets confirmation of that I'll cancel the Suncoast B/O. I think the expedited shipping was $71 but my price at the dealer was less than suncoast so close to a wash.
Thescout13 (11-02-2022)
#57
Mine came in today. After cancelling with Suncoast, I ordered through independent shop. Shop got it from Germany in 3 days. Then another couple days to ship to me. So about 5 days total. Meanwhile, two months and Suncoast still has nothing.
#58
Done.
Done.
#59
I'm a bit confused here. Haven't tried to install yet. But my ****/boot came with the **** turned CW. So I imagine to lock it, you'd turn the **** CCW. But you're saying the opposite. Unless you install with **** already centered and you grab the collar underneath the boot and turn that instead?
RDCR (11-03-2022)
#60
Fixed:
The following 2 users liked this post by FourT6and2:
RDCR (11-03-2022),
Thescout13 (11-04-2022)
