Tractive DDA RT coilover review
What are the spring rates for the tractive setup? 130nm front and 200nm linear? The factory for 991.2 gt3rs / gt2rs is 100/160 which is a huge difference front to back. Manthey KW setup is a 120/170, MCS is more like 110/150.
I worry about such a difference front to back as this is one thing most of the ohlins, kw, MCS agree upon is getting those spring rates closer but the tractive is expanding it? Also, for the tractive, is it a 2-way system? electronic controllers for rebound and compression but not fine grain for high / low speed?
4 Point 0 (11-13-2021)
Premium Sponsor
We don't have a one-fit-all spring rate. Each set of coilovers we sell includes consultation to the customer to determine the most ideal spring rate with consideration for any mods on the car and the intended usage. For example, on a 991.1 GT3/RS and 991.2 GT3 it is popular to go with 100/160nm springs for street and track. This setup rides nicer than OEM dampers and great track performance. 100/160 is what comes standard on a .2RS. We up the spring rates for customer who prefer to focus more on track performance and are willing to give up a little bit of road compliance.
PCA National Instructor
TPC Racing stats:
2023 Porsche Sprint Challenge 992 Cup Am Champion
2023 Porsche Sprint Challenge GT4 Pro-Am Team Champion
2022 Porsche Sprint Challenge 992 Cup & 991 Cup Champion
2020 IMSA GT3 Cup Challenge 2nd Championship
2018 IMSA GT3 Cup Challenge 2nd Championship
2016 IMSA GT3 Cup Challenge Champion
2013 IMSA GT3 Cup Challenge Champion
2006 Rolex-24 @ Daytona GT Champion
2004 Grand-Am SGS Class Champion
TPC Racing stats:
The DSC controller for the stock dampers basically turns them into 6 ways...So I'd assume they would at least have that capability.
Premium Sponsor
Conventional manually-adjusted 2-way dampers typically have two settings, they are Compression and Rebound. The Compression and Rebound can be divided into High-speed and Low-speed which then the damper is referred to as 3-way or 4-way. These are all static settings; meaning once you set each adjuster dial(Compression, Rebound, High/Low speed), it is the absolute damping characteristic until you stop the car, get out of the car, and turn the adjuster dial(s) again.
DSC V3 controller dynamically commands electronic dampers in a way that is well beyond the conventional Compression and Rebound that are often referred to in the manual-adjusting world. With DSC dynamic damping technology the primary load is g-force(actual g-force value, direction of g-force, and rate of change in g-force). The primary load is the absolute value for a moment until there is a change in g-force. Brake Line Pressure, Steering Angle, Throttle Movement, and of course High-speed, Med-speed, and Low-speed Compression and Rebound are offsets to the absolute value, in real time. Here's the DSC Travel Velocity Table-
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/839x525/dsc_velocity_compression_e642a8bb4498e52e8561598760cbd904a3e7ca24.jpg)
DSC stands for Dynamic Suspension Control. This acronym is precisely what the DSC product does, in a dynamic(or active, or reactive) multi-dimensional way.
The 991 OEM PASM dampers are very good. They have a reaction time of ~100 millisecond to command. Which is 10x per second. Very impressive for mass-produced OEM dampers. Noticeable improvements in performance and comfort can be had by using DSC with OEM dampers.
For the pinnacle in electronic dampers, we offer the DSC RT coilover dampers featuring the patented Tractive DDA electronic Spool-valve with 6 millisecond reaction time(166x per second), true bi-directional operation to react to command during mid-stroke unaffected by external compression pressure, ultra-wide dynamic damping force range, and top-tier build quality.
The following 4 users liked this post by Tom@TPC Racing:
Great review, thanx or sharing. I am one of those that has decided not to mod my car (I do have the rear wing Baron uprights) but if my plan holds to keep the GT2 car long term, of which I will know in the next 2 1/2 years, I can see modding/tracking her downrange. BTW does Ohlins make a coil over for our RS cars?
mr965 (01-07-2021)
Premium Sponsor
The following 5 users liked this post by Tom@TPC Racing:
KA 991 GT3 (06-30-2021),
MotoJB (03-20-2021),
mr965 (01-10-2021),
sgreer78 (01-07-2021),
vokain (04-19-2023)
GT3 player par excellence
never believe in active suspension.
997/991 meh
then I drove tractive (on totally different platform not gt3)
WOW....
short of u having a chassis engineer with you 24/7 and adjusting for u, this is close to the END GAME
997/991 meh
WOW....
The following 3 users liked this post by mooty:
Wanted to follow up with a track review of this setup...
Just got back from 2 days at Mid-Ohio running with Chin Track Days. Lots of track time and many laps - as many as my 2 year old Cup2Rs would handle. The car performed amazingly well. It transitioned weight in a very controlled manner and allowed me to put down power easily on corner exit. The transitions were smooth and controlled, and I could dial in the electronics if I felt the need (I didn't - the map the team at TPC has works extremely well). I was talking with another RS owner (a .2) who is an ex-racer and Mid-O is his home track. He's very fast there (and gave me some pointers to improve!) - he said he was shocked at how quickly my car would apply power and bolt out of the corners. Pretty good given I only have a lowly .1 RS.
I'm still learning the suspension overall, but I'm convinced it's an amazing product and I'm looking forward to spending more time behind the wheel. Anyone on the fence and spending a reasonable amount of time on track - get it. It's good stuff.
It's so good my buddy in a GT350R just bought the same setup for his car.
*Note - I'm not affiliated with TPC or DSC or Tractive at all - just a satisfied customer*
The following 2 users liked this post by QuickOne:
Tom@TPC Racing (06-04-2021)
After 2 days at Laguna with the Tractive DDAs on my 991.1 I have to say this is the best mod I have ever done to any of my cars. Coming from a GT4 that had the Swift spring upgrade, full monoballs and DSC the GT3 stock left a lot to be desired to me in terms of the overall stability of the car turning in, braking, transitions etc to the point that I never felt very comfortable tracking it. I went with .2 RS spring rates and had solid monoballs added as well and this just transformed the car. The result was 1.2 seconds off my PB and average lap times were 2 seconds better OA as well. Times aside the confidence and comfort level I now have with the car - "Priceless". I could feel the difference on some hard HWY 9 runs before I had the track days so I knew this would be a great street upgrade as well for anyone looking for more in the twisties. The street ride is more harsh than OEM but only over very bad roads. ![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Tom@TPC Racing (06-30-2021)
I'm actually going to pull these off my 991.1RS, along with the monoball setup, and move them on to someone new. Am converting the car back to stock-ish to sell as I'm building a new track car for my son and I to drive. I think the RS, especailly in track weapon form, might be too much for him - and too expensive if he makes a mistake.
I'm sure these coilovers will find a good home soon!
Premium Sponsor
Premium Sponsor
