Is your harness bar/cage quiet?
#31
I have the same GMG LMS bar as the OP and it's been quiet. When I first installed it, it made a ton of noise, and then I realized that I didn't torque down the front-most bolts (the ones that mount on the vertical portion where a rear passenger's knees would be). Once I torqued that down, quiet. Of course the harnesses themselves make noise if you don't have them buckled to the camlock, especially if you're using the eyebolts/clips.
I actually picked the GMG because I liked that it mounted on top of the strut. Even though that's a more painful install, I figured maybe it would add meaningful rigidity. All things being equal anyways. It felt like there were many very similar bars and it was easy to have decision paralysis.
