Michelin Cup 2 R K1 (Ferrari Spec) on GT3?
The weight ratings are different on rears, e.g. the 305 is 103Y and the 325 is 108Y.
Basic Sponsor
I might suggest educating yourself a little further before calling people idiots
JC
JC
WE'RE NO LONGER ACTIVE ON THE RENNLIST FORUMS - FOR ALL ENQUIRIES PLEASE CONTACT US VIA THE JCR WEBSITE BELOW
/ / / JCR PORSCHE \ \ \
contact@jcr-developments.com
Facebook | Instagram | Youtube
Basic Sponsor
If you take a look at the title of the thread - Michelin Cup 2 R K1 (Ferrari Spec) on GT3? - We're discussing the GT3 tyre vs the same size Pista Cup2R.
I think you're getting a little confused with GT3 RS sized tyres. No one ever mentioned GT3 RS and comparing a different sized tyre has absolutely no relevance to this thread.
JC
Search K1 and orthojoe and you’ll have your answer.
Pista Cup2 R with K rating is the same construction as the GT3 sized Cup2 connect (245/35/20) (305/30/20)
Ferrari actually had no technical input into the tyres construction, this is a marketing spin. Car manufacturers make the cars, tyre manufactures make the tyres and unless it's a very specific and unusual application, think Veyron and Chiron then the manufactures simply develop and refine the chassis and handling characteristics around the tyre that's suggested to them. Koenigsegg are a prime example of this.
It's a common misconception driven mostly by tyre markings that its the tyre manufactures designing their tyres around the car. Kind of in the same way that you wouldn't imagine Tennis ball manufactures develop the ***** to suit the companies that produce the rackets![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
JC
JC
The following 2 users liked this post by Seth Thomas:
hellboy_mcqueen (06-12-2020),
mdrums (06-20-2020)
SterlingatBOM (06-10-2020)
Basic Sponsor
This is not 100% true. Tire manufacturers do build different spec tires for different car manufactures. Case in point is Pirelli. While I was working on a program with McLaren North America the 650S was brand new and we would take all the cars to the track with the Pirelli P-Zero Corsa tires. The fronts were a 235/35/19. For our second track day we were sent a pallet of the Corsa front tires but they were the standard Corsa and not the ones with the MC1 stamped on the side. At Monticello Motor Club the cars were all over the place under braking. The rear end squirmed under the dive of the front end. If any of the cars still had a the MC1 tire on it the squirm was not there. You could back to back drive the cars in this configuration and could immediately tell a difference. If you looked at the tires and the specs on the sidewall there wasn't a single difference other than MC1 stamp on the tires that did not have squirm. From that experience I can tell you there is a difference in the proper manufacturer spec tires on a car when on the racetrack. For the street I don't believe it would matter as much but on the track it was a big difference.
The variation between Pirelli tyres set to set is also something to be considered
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
JC
At a track day, folks will vary on, I like this tire or I like that tire.
On a forum, folks think if they don't buy the right tire, the car will fall apart driving to the local McDonalds taking the "fun" route.
I suggest you look at the different weight ratings for different tire sizes in the Porsche range of sizes - there are a lot of tires and a lot of those don't have the correct weight class. Putting the wrong weight class tires on your car is bad news particularly in regard to the rear. Moreover there are clear differences between the N ratings even within the same size group - which can relate to change in compound, sidewall protection and even tread variation. Furthermore, different manufactures have different specs for the same tire group - so an AM, MC, N or K stamped tire may still be called a Cup 2R or Cup2 (or 4S) however there are differences sometime minor, sometimes significant. I know for a fact Porsche and Michellin will through some 800 test tires before they settle on a specification. Sounds like its you who needs the education.
That's exactly marketing for you. The manufacturer has to make a slight variation to legally call it a different tire model. For most track day enthusiasts, do you think it's worth 20,30% premium??? Your description makes it sound as if non-MC1 tires are absolutely garbage and unsafe on a McLaren. Is it? Doubt it. Maybe your braking style is different....lots of variables. I've driven with SC2's and Trofeo R on the same car and it's very subjective for a track day enthusiast and that's your target market. These aren't racing tires used for racing so the variation is used for marketing and it's essentially the same tire. That's the point folks are trying to make.
usrodeo4 (08-11-2020)
Basic Sponsor
I’m not arguing that tyres differ size to size between applications but again, we’re talking about a very specific application here. Not Mercedes, not McLaren. In this specific case there isn’t a difference.
Im not writing these things to be edgy or come across clever, I’m answering a question that the OP asked based on knowledge coming from the horses mouth.
Maybe we will have to agree to disagree on this one
JC
So the load ratings were critical until I proved they were the same and now they mean nothing? ![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
JC
JC
Thats why I don't listen to people like you - it works like this, you fit what I say to my car in the way that I want it. If not, I go somewhere else. Why, because I've done a lot more of this than you.
As a comment to your offerings on your website - perhaps you should get some body kits for dimwits from canary wharf, perhaps offer a Cxxx tune
